Drywall Ceiling And Electrical - Electrical - DIY Chatroom Home Improvement Forum
Old 02-14-2013, 12:51 PM   #1
Question
Drywall Ceiling and Electrical
Hi guys, I am new here and have tried searching, but I can't find anything i am looking for.
I am looking to drywall my ceiling now that I've removed the drop ceiling, but I've got a few electric wires that I need to contend with. I'll post pictures when I have the ability to. The ceiling is low anyways ~7ft. 4in., so I would like as much clearance as possible.
Basically I've got the main electrical line that comes into the house, a coax cable, and a phone line that run along the bottom of the joists perpendicular across 9-10 joists, then run along one of them to their respective spots. I know that I can drill a hole for the coax cable and re-run it, however I am not sure what to do with the phone line or the electrical wiring. I would ideally like to drill holes, but i would have to get service shut off to the house, undo the wiring at the box and re-run it through the holes that I would drill. We don't use the phone service at all, but I don't want to remove it in case we move and the next owners would like to.
As an alternative, is there a way that I could add furring strips to the joists to provide room for the wiring to exist where it does now? How would I go about doing this if it is an option?
Thanks in advance to everyone!
bpalmer05 is offline   Reply With Quote
Old 02-14-2013, 01:10 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by bpalmer05 View Post
I am looking to drywall my ceiling...
The ceiling is low ~7ft. 4in.so I would like as much clearance as possible.
I've got a few electric wires that I need to contend with...
is there a way that I could add furring strips...
depending on about 30 variables...
the answer is to *move* them to one end/side and then to box them in.
Think "soffit".
Post some pics if you want more specific ideas.
The Following User Says Thank You to TarheelTerp For This Useful Post:
electures (02-15-2013)
Old 02-14-2013, 05:32 PM   #3
Rewards Points: 13,450
Far simpler to just screw some 2 X4's. to the joist.
Old 02-14-2013, 06:09 PM   #4
MCB
sparky
If you box it in, be sure to put lots of "mechanical protection" over the service coming in, like metal plates all along it so the next guy doesn't run a screw into it....
MCB is offline   Reply With Quote
Old 02-14-2013, 06:37 PM   #5
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Using furring strips should work and add nail plates and strips of steel anywhere the wire is really close to where the drywall will be put up.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 02-15-2013, 10:10 AM   #6
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Think "soffit".
Exactly what I was thinking.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 02-15-2013, 10:48 AM   #7
Would I run the furring strip perpendicular or right along the bottom of the joists? I plan to put a steel plate underneath the electrical for protection, and I am also going to diagram where the cables and vents are located for myself and future homeowners if we ever sell the house.
Installing Ceiling Fan Electrical Box (Old Construction) jtslue24 Electrical 7 09-16-2012 12:58 PM
Ceiling fan electrical box Pittsville Building & Construction 11 11-26-2011 07:14 AM
Cover electrical boxs in ceiling netplayn Electrical 8 07-20-2010 08:49 PM
Electrical ceiling box for ceiling fan DIYguy2000 Electrical 4 11-04-2009 12:31 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
