Dryer Receptical - Electrical - DIY Chatroom Home Improvement Forum
Old 10-22-2010, 08:34 PM   #1
dryer receptical
I need to run a receptical for my dryer. I have left over 6/3 from my stove which is overkill but will save me from buying 10/3. The dryer is located in the basement. My question is do I need to run conduit the vertical length from the floor joists down the foundation wall to the receptical or can I attach a board to the wall and then staple the cable to the board?
thanks!
berg76 is offline   Reply With Quote
Old 10-22-2010, 09:39 PM   #2
Licensed electrician
Rewards Points: 1,266
Attached to a furring strip should be fine.
Old 10-22-2010, 10:36 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
you have 6/3 what? and just to be sure, it is 6/3 plus ground, right?
Old 10-22-2010, 10:40 PM   #4
" Euro " electrician
frenchelectrican's Avatar
Also make a note on the 16mmX3 conductor that is used for dryer so in case someone else don't get this mixed up with range or other hevey circuit.
Merci.
Marc
Old 10-23-2010, 07:19 AM   #5
Electrician
Rewards Points: 778
You will also have to check the lugs on the dryer plug to make sure they can handle #6 wire, if they can't you could make a joint and bring it down to #10 at the box but that will fill your box up very fast.
darren is offline   Reply With Quote
Re-route dryer electric cable Stu27 Electrical 10 09-06-2010 09:21 PM
Dryer exhaust duct not connected inside dryer frankrizzo Appliances 4 02-09-2010 09:47 PM
Please look at this dryer vent installation Andy Griffith Appliances 6 08-31-2009 01:39 PM
Dryer vent ponch37300 General DIY Discussions 10 01-21-2009 05:26 PM
Dryer Pony Problem. Hobb3s Electrical 17 09-30-2008 09:16 PM
