-   -   dryer receptical (http://www.diychatroom.com/f18/dryer-receptical-84662/)
berg76 10-22-2010 07:34 PM
dryer receptical
I need to run a receptical for my dryer. I have left over 6/3 from my stove which is overkill but will save me from buying 10/3. The dryer is located in the basement. My question is do I need to run conduit the vertical length from the floor joists down the foundation wall to the receptical or can I attach a board to the wall and then staple the cable to the board?
thanks!
Jim Port 10-22-2010 08:39 PM
Attached to a furring strip should be fine.
nap 10-22-2010 09:36 PM
you have 6/3 what? and just to be sure, it is 6/3 plus ground, right?
frenchelectrican 10-22-2010 09:40 PM
Also make a note on the 16mmX3 conductor that is used for dryer so in case someone else don't get this mixed up with range or other hevey circuit.
Merci.
Marc
darren 10-23-2010 06:19 AM
You will also have to check the lugs on the dryer plug to make sure they can handle #6 wire, if they can't you could make a joint and bring it down to #10 at the box but that will fill your box up very fast.
