Dryer Receptacle - Electrical - DIY Chatroom Home Improvement Forum
Old 12-10-2011, 04:31 PM   #1
dryer receptacle
I have 10/3 wire going to a four plug receptacle but the dryer we have is a 3 prong (2 slants and an L). Can I change the receptacle using the 2 hots and ground and capping the other ground? Change the wire on the dryer? Any suggestions?
freemike is offline   Reply With Quote
Old 12-10-2011, 04:34 PM   #2
Licensed electrician
Rewards Points: 1,870
The proper thing to do is to change the cord to a 4 wire cord. You will also need to remove the bond strap on the dryer.
Old 12-10-2011, 06:33 PM   #3
where do I connect to fourth wire
where would I connect the fourth wire on the dryer? Thanks.
Old 12-10-2011, 06:37 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,990
Red, white & black on the terminals under the cover. The green wire goes to the green screw. The existing wire under the green screw gets put under the screw with the white wire.
Another Dryer Question 3 to 4 wire John3rd Electrical 15 07-29-2015 01:10 PM
Box Size for Dryer Receptacle sirsparksalot Electrical 12 05-02-2011 09:36 AM
Grounding Dryer Receptacle Montana Sailor Electrical 10 04-20-2010 07:43 PM
4-prong dryer receptacle algraz Electrical 2 08-10-2009 03:04 PM
New Dryer is 3 wire, receptacle is 4 Wire. thelimit Electrical 22 01-15-2009 09:59 AM
