Old 11-19-2009, 02:20 PM   #1
dryer question
I have a 3-prong dryer connector that reads 110v from one straight leg to the L leg, no volt between the other straight leg and the L leg and no volts between the two straight legs. This dryer worked in the past.
cawlady is offline   Reply With Quote
Old 11-19-2009, 02:49 PM   #2
Licensed Pro
dryer question
Loose connection on one hot wire or bad breaker. Usually bad breaker.
Old 11-19-2009, 04:49 PM   #3
It was a dark and stormy
Yoyizit's Avatar
dryer question
Or a short in the dryer caused the breaker to trip.
If resetting the breaker restores the voltage, put a 120v 10A hair dryer from the ground terminal to one side of the line, then the other, so the hair dryer sees only 120v each time.
If the voltage to the hair dryer rises substantially more than ~1v [e.g., from 119vac to 120vac] when the hair dryer is switched off you have a bad connection.
Test both lines. If the hair dryer fan doesn't run, turn it off immediately; you have found your problem.
If the power source passes this test, almost certainly the dryer has a problem. Much less likely, both have a problem.
Old 11-19-2009, 08:11 PM   #4
jman electrician
dryer question
Could be a loose wire at receptacle/plug
loose or damaged wire in appliance
loose wire at breaker (it's not actually under screw)
or it could be a bad breaker.
I've experience all 4 problems with the clothes dryer.
Sparkykaboom is offline   Reply With Quote
Old 11-19-2009, 08:23 PM   #5
My License Ain't 4 Sale..
dryer question
It may also be a fuse. If a dryer is connected to a fuse block, there will be two fuses, and one of them may be blown.
Dryer on the fritz.. wiring problem? cisco10 Electrical 17 11-19-2009 02:26 PM
New electric dryer is blowing breaker! minameismud Electrical 7 09-14-2008 11:45 PM
Dryer Vent Question jlaky2000 HVAC 2 03-13-2008 09:22 PM
Problem with ELECTRIC DRYER plugs SpaceCrawler Appliances 6 06-03-2007 11:21 AM
Location of 220 and 110 outlets for dryer and washer JAJJ Electrical 2 08-07-2006 10:16 PM
