Dryer Outlet Vs. Range Outlet - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-12-2009, 05:56 PM   #16
Nice picture nap, what's that all about???????.
SULTINI is offline   Reply With Quote
Old 04-12-2009, 05:57 PM   #17
quote
Whoever Quotes Larry the cable guy , I got a lot of respect for him. NOT...
Old 04-12-2009, 06:09 PM   #18
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
hey sultini, how much do you weigh?
Old 04-12-2009, 08:46 PM   #19
probably 98 lbs sopping wet, with a load
Old 04-12-2009, 11:47 PM   #20
Idiot Emeritus
Rewards Points: 1,492
Cinda, if you're still reading this anymore, the answer to your question is if the 8/3 has 3 insulated conductors ( usually black, red, and white) you certainly can use it for a dryer.
Simply install a 2 pole 30 amp breaker, put the black and red on the breaker and the white on the ground/neutral bus. (It's the one with all the other white and bare wires on it).
Install a 30 amp 3 wire 'crowfoot' receptacle. Get a 3 wire dryer cord to match the receptacle. If the dryer already has a 3 wire cord on it, you're done.
If the dryer had a 4 wire cord on it, you'll need to bond the frame of the dryer to the neutral. (it's the center wire of the cord). There's likely a bonding strap near the terminal block. Just connect the loose end of it to the terminal with the center cord wire.
If you need more help, please post again here. There's about a dozen of us here who know how to do this properly.
Rob
micromind is offline   Reply With Quote
Old 04-13-2009, 04:10 PM   #21
nap
You talking to me?
nap's Avatar
Rob
Rob, how about the legalities of NEW dryer circuit requiring a 4 wire system? Since this is not a dryer circuit now, I would see that changing it to a dryer circuit would not allow the grandfather clause that allows the continued use of 3 wire circuits for dryers.
Obviously, if the 8/3 is plus ground, it's cool but if there is only 3 conductors, I believe it must be changed to a 4 wire conductor as I said above.
Old 04-13-2009, 05:33 PM   #22
I currently have a 50 amp outlet on 8-3 wire. I know this is for a range. The problem is it is where my dryer is suppose to go. Can I remove the range outlet and connect the 30 amp dryer outlet to the same wire? Or do I have to run new 10-3 wire and replace the 50 amp breaker with a 30 amp?
It's never as easy as you'd like it to be
"Yes you can" refers to : "Can I remove the range outlet and connect the 30 amp dryer outlet to the same wire?" along with "replace the 50 amp breaker with a 30 amp?"
As Nap pointed out, a hard assed inspector would argue that since you are changing it from a range to a dryer, it won't fall under the "grandfather" clause allowing existing 3 wire installations of ranges and dryers.
The most simple answer is generally the best. Change the breaker and the recep, plug it in and move on.
220/221 is offline   Reply With Quote
Old 04-13-2009, 05:49 PM   #23
Scuba
The next time you go Scuba Diving why not forget your mask, or forget to open the 02 valve.
Talk about sopping wet.
Old 04-13-2009, 05:50 PM   #24
oooohhhh witty
I've yet to dive with O2
Old 04-13-2009, 06:01 PM   #25
oooohhhh witty
Got to try it it makes you smart.
Tags
30 amp , dryer , outlet
Replace Range Outlet Suncrest79 Electrical 22 04-14-2009 11:32 PM
Dryer outlet Davide Electrical 3 02-25-2009 11:48 AM
Range outlet pushes oven too far from wall givemeabreak Electrical 8 08-19-2008 12:14 AM
changing a range outlet or plug marty7 Electrical 9 12-17-2007 10:11 PM
Clothes Dryer / Outlet homercavazos Electrical 8 10-30-2007 04:14 PM
