Dryer Outlet Vs. Range Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 04-11-2009, 01:52 PM   #1
Dryer outlet vs. Range outlet
I currently have a 50 amp outlet on 8-3 wire. I know this is for a range. The problem is it is where my dryer is suppose to go. Can I remove the range outlet and connect the 30 amp dryer outlet to the same wire? Or do I have to run new 10-3 wire and replace the 50 amp breaker with a 30 amp?
cindakay is offline   Reply With Quote
Old 04-11-2009, 02:33 PM   #2
dSilanskas's Avatar
Yes you can
dSilanskas is offline   Reply With Quote
Old 04-11-2009, 02:57 PM   #3
You can use the same wire
I'm just not sure if you can leave the 50a breaker for a 30a appliance
I would think not?
OOps - missed that - you are installing a 30a breaker
Old 04-11-2009, 03:44 PM   #4
dSilanskas's Avatar
No he said he was replacing the 50 for a 30
Old 04-11-2009, 06:00 PM   #5
50 on 8 is wrong anyways.
rgsgww is offline   Reply With Quote
Old 04-11-2009, 11:54 PM   #6
...say what?
unclduey is offline   Reply With Quote
Old 04-12-2009, 12:11 AM   #7
Originally Posted by unclduey View Post
...say what?
A 50 amp overcurrent device can not protect 8 awg wire if in the 60c table.
Old 04-12-2009, 09:53 AM   #8
Electrician
SD515's Avatar
Rewards Points: 504
You can use the existing 8/3 wiring with a new 30A dryer receptacle if you also change the breaker to a 30A. You can always use a breaker rated less than the rating of the circuit it's protecting.
Kyle
Old 04-12-2009, 12:00 PM   #9
All this
Originally Posted by dSilanskas View Post
Yes you can
Wow!!
All these posts when dSilanskas made it quite clear with the first one.
I think you guys want to read what your saying.
DIY is confusing even to experienced mechanics let alone DIYers.
SULTINI is offline   Reply With Quote
Old 04-12-2009, 12:04 PM   #10
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Unfortunately "Yes you can" wasn't the correct response to the questions asked.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 04-12-2009, 12:21 PM   #11
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
Originally Posted by SULTINI View Post
Wow!!
I really think you may want to follow sentence #2 in your own advice. As stubbie posted, "yes you can" is not the answer, especially considering there were several questions in the first post.
so, quit being an INsultini and get with the program.
Old 04-12-2009, 02:45 PM   #12
Yes
Nice answer STUBBY.
Old 04-12-2009, 02:53 PM   #13
Insultini
I re read my reply didn't really see an insult.
By the way nap the name you used for me, has been used for 40 years now you ain't gitin no Cherry wise guy.
And how do you know I ain't wiyth the program????????????
PS I gott spelll chek but it's not worth using for yo.
Old 04-12-2009, 05:20 PM   #14
UAW SKILLED TRADES
Stubbie's Avatar
Why on earth would you let people call you that for 40 years?
The response by dsilanskas failed to address the questions to confirm code compliance. Had Cindy replied we could have reached that with a few more questions. You seem to approve of the answer given in post 2....why?
If I answered that question with "yes you can" it would be incorrect. A new cable would require 10/3 with ground...4 wires.... this would be the preferred method if possible. If Cindy keeps the 8/3 (no ground) it must be an SE cable or a cable with an insulated neutral.... we haven't determined that yet. And Cindy needs to know about the no bonding requirement at the terminal block of the dryer if she changes to 4 wires. So I am baffled at why you would think that "yes you can" should have been the end to this thread???
BTW I have an extreme dislike for internet policeman who come in on a thread for no other reason that to make an attempt put themselves on a pedestal and judge the others who are trying to ask the right questions. You offered nothing to this thread but an insulting statement. So don't walk a mile out of your way to try to hide why they have called you by that nickname for 40 years.
Stubbie
Old 04-12-2009, 05:25 PM   #15
nap
You talking to me?
nap's Avatar
the INsultini just fit so well though even though it was not necessarily on point, then, but due to this:
it fits.
All I was saying is you were chastising others for what they posted yet you referred to a post that most definitely did not provide a proper answer. There are some pretty bright bulbs (I guess that should be lamps in light (easy pun) of the NEC usage of terms) around here. We tend to be a somewhat self correcting forum due to that and the general relationship and interactions of the members.
Tags
30 amp , dryer , outlet
Replace Range Outlet Suncrest79 Electrical 22 04-15-2009 12:32 AM
Dryer outlet Davide Electrical 3 02-25-2009 12:48 PM
Range outlet pushes oven too far from wall givemeabreak Electrical 8 08-19-2008 01:14 AM
changing a range outlet or plug marty7 Electrical 9 12-17-2007 11:11 PM
Clothes Dryer / Outlet homercavazos Electrical 8 10-30-2007 05:14 PM
