Dryer Outlet Adjacent To Laundry/utility Sink - Electrical - DIY Chatroom Home Improvement Forum
Old 02-12-2008, 09:55 AM   #1
Dryer outlet adjacent to laundry/utility sink
Hi all,
I'm in the final stages of a basement remodel and I have a code question...
My new laundry will be set up along the back wall of the room (from left to right) like this: Wash machine, clothes dryer, laundry sink. As is, the new dryer receptacle (4-wire) is located less than 12" from the edge of the Laundry sink.
I had the inspector here today, and he said everything else looked great, but he had to check the code for the dryer receptacle. He said I may need to put a 30amp gfi breaker in the panel.
Since those are kind of pricey, I was wondering if anyone had any thoughts or could cite an NEC exemption if there is one.
Thanks,
Ben
bjstewa is offline   Reply With Quote
Old 02-12-2008, 10:39 AM   #2
Licensed Pro
Only 120V, 15 and 20A receptacles within six feet of a laundry sink are required to be GFCI protected. The dryer is 120/240V, 30A, so there is no NEC requirement for GFCI protection.
Old 02-12-2008, 10:39 AM   #3
Rewards Points: 2,350
Tell the inspector to look at 210.8(A) of the NEC. The first statement of this article is:
"All 125-volt, single phase, 15- and 20- ampere receptacles installed in the locations specified in (1) through (8) shall have ground-fault circuit-interrupter protection for personnel."
The key here is "125-volt, single phase, 15- and 20- ampere..." Since the dryer circuit is 240-volt 30-ampere, you are A-OK.
InPhase277
Old 02-12-2008, 11:44 AM   #4
Thanks guys - much appreciated...
Ben
Old 02-12-2008, 12:46 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,968
Are you serious???? The inspector actually said that????
WOW!
If this is completely true that man has NO place doing electrical inspections.
Old 02-12-2008, 08:10 PM   #6
Union Electrician
goose134's Avatar
Speedy, the upshot is that he didn't flag it outright, he did say he'd check.
goose134 is offline   Reply With Quote
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Outlet installed under sink, under cold water valve? akinito Electrical 3 01-10-2008 08:55 PM
outlet under kitchen sink longswl Electrical 9 11-21-2007 10:16 AM
Clothes Dryer / Outlet homercavazos Electrical 8 10-30-2007 04:14 PM
outlet for a dryer econdave Electrical 16 08-16-2007 05:47 AM
