Dryer Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 05-19-2008, 03:49 PM   #1
Dryer outlet
I now have a 3-pole 240v flush mounted outlet with only 3wires in the plastic box, no ground. The new dryer is already wired with a 4-prong cord. The 4-prong otlet I bought has a connection for ground. What to do?
stan 41943 is offline   Reply With Quote
Old 05-19-2008, 04:36 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
Replace the 4-wire cord with a 3-wire cord and plug it in.
The receptacle/circuit determines what cord you use, NOT the other way around.
Old 05-19-2008, 04:59 PM   #3
Other threads I have found described changing from 4-wire to three requires modifying the grounding in the dryer,when 3-wire is used. Could I run a ground wire into my outlet box & attach it to a copper pipe & keep the 4-wire plug? They will be delivering the units tomorrow & installing them in a small space(I'll be at work). I'm hoping to do what's needed tonight so the "muscle guys" can hook it up, the wife can use it, & when I get home I can reap the rewards of wife's gratitude.
Old 05-19-2008, 05:58 PM   #4
ABSOLUTELY NOT. A "copper pipe" DOES NOT proved a safe and adequate ground 99.9% of the time.
To use a 4-wire receptacle you must run a new cable with a dedicated ground wire. 10/3NM is typical.
Old 05-19-2008, 06:00 PM   #5
Originally Posted by Joba Fett View Post
That statement is ridiculous.
Yeah, like you would know.
Old 05-19-2008, 06:08 PM   #6
This is of course assuming the existing cable is not already 10/3w/g.
Old 05-19-2008, 07:00 PM   #7
Electrician
Install a 4 wire cable (HHNG) to serve this dryer.
The OP already stated he had a three wire receptacle, with no ground. So three wire cord it is.
chris75 is offline   Reply With Quote
Old 05-19-2008, 07:38 PM   #8
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
HHNG? What's wrong with NM? I've never installed any HHNG cable.
John
jrclen is offline   Reply With Quote
Old 05-19-2008, 08:01 PM   #9
And the OP stated he had a 4 wire cord which came on his dryer.....learn how to read.
No kidding. I read that.
What does it have to do with the circuit that is existing or run?????
THE CORD IS NOT the determining factor!
Old 05-19-2008, 08:37 PM   #10
Electrician
Rewards Points: 802
To help this DIY, I used a laymens' convention HHNG (hot-hot-neutral-ground) you learn as you learn. If you looked closely, I SAID 4 wire cable, and tried to help this DIY.
And I sure do know his initial post was ridiculous.
I beleive people are starting to bulls*&T with you. I beleive he figured out HHGN, it does say he is an licensed electrician.
I have never seen it written on any print or ever heard anyone say HHGN. All you have to say is the dryer is 120/240V 30A and if you can't figure out that you need 10/3 then you should hire someone to do the work.
darren is offline   Reply With Quote
Old 05-19-2008, 08:44 PM   #11
Jeeze. Go back and look at JR's post.
Do you know what this " " is???
Of course he was messing with fett.
Old 05-20-2008, 04:08 AM   #12
Thanks guys. I replaced the 10/2 with 10/3/g and 4 wire recepticle from the panel.
Old 05-20-2008, 05:35 AM   #13
Electrician
Dryer outlet adjacent to laundry/utility sink bjstewa Electrical 5 02-12-2008 08:10 PM
wiring outlet for electric dryer TSMO Electrical 7 11-26-2007 09:51 PM
Clothes Dryer / Outlet homercavazos Electrical 8 10-30-2007 04:14 PM
outlet for a dryer econdave Electrical 16 08-16-2007 05:47 AM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 08:45 AM
