Dryer Outlet - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Closed Thread
Old 05-01-2013, 09:32 PM   #31
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Originally Posted by analogmusicman View Post
you know,99% of the sections of this forum (carpentry,plumbing etc.) have actually provided me with some good info, but this one (electrical) is the "pits"! must be that electricians in general are a pain!
The other sections won't kill you in a New York minute either...
k_buz is offline
The Following 6 Users Say Thank You to k_buz For This Useful Post:
HouseHelper (05-01-2013), Jim Port (05-01-2013), jproffer (05-01-2013), mpoulton (05-01-2013), Nailbags (05-04-2013), stickboy1375 (05-01-2013)
Old 05-02-2013, 01:02 AM   #32
" Euro " electrician
frenchelectrican's Avatar
Not really depending on whom ya try to deal with it and I have see some members in here and other fourms are alot worst than your action is.
But try that over here in France it will turn your mind upside down a little bit.
Really in fact over here it is the other way around The electical side is not too bad but plumming over here is let say " Fou "* that all I am saying for now.
Merci,
Marc
* Fou = Crazy
frenchelectrican is offline
Old 05-03-2013, 11:28 PM   #33
Rewards Points: 184
Can 10/2 w/ground (type NM) be used from panel to a/c disconnects?
stevekem is offline
Old 05-04-2013, 04:58 AM   #34
Electrical Contractor
kbsparky's Avatar
Yes, since the ground wire is NOT being used as a current-carrying conductor. When used as a neutral (as is the case in this particular thread), it IS carrying current as part of its normal operation.
Hence the Code violation.
-KB
kbsparky is offline
The Following User Says Thank You to kbsparky For This Useful Post:
stevekem (05-04-2013)
Old 05-04-2013, 08:29 AM   #35
Licensed electrician
Rewards Points: 1,010
An air conditioner is a straight 240 load. It does not need a neutral. Dryers and stoves have neutral current from timers, lights and motors.
Jim Port is offline
Old 05-04-2013, 11:01 AM   #36
Rewards Points: 626
No your wrong, They won't kill you or burn your home to the ground in a New York nano second.
Nailbags is offline
Old 05-04-2013, 03:28 PM   #37
Hmm, whats more life threatening, a fire or a leak?
Olsy is offline
Closed Thread
converting a 4 prong dryer outlet into a 3 prong dntbro1994 Electrical 8 07-02-2010 11:25 PM
Adding a 220v jointer to a dryer outlet popeka Electrical 7 12-13-2009 10:33 PM
Dryer outlet Davide Electrical 3 02-25-2009 12:48 PM
electric dryer - Chord and Outlet question? WILLIAM RIDGE Electrical 2 12-14-2008 10:45 PM
Running AC off of a Dryer Outlet TheCrow Electrical 7 06-16-2008 08:11 PM
