Dryer Outlet - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Closed Thread
Old 04-30-2013, 08:27 PM   #16
Just call me Andrew
Rewards Points: 1,020
Silly question - what's wrong with the original receptacle?
Andrew
secutanudu is offline
Old 04-30-2013, 08:27 PM   #17
analogmusicman's Avatar
Rewards Points: 560
you know,99% of the sections of this forum (carpentry,plumbing etc.) have actually provided me with some good info, but this one (electrical) is the "pits"! must be that electricians in general are a pain!
analogmusicman is offline
Old 04-30-2013, 08:33 PM   #18
Just call me Andrew
Originally Posted by analogmusicman View Post
well,for me it IS that easy since I'm not licensed and have to answer to an innspector.
tnx,
Guys, i think he is saying he DOES have to answer to an inspector, so he wants to do it correctly.
Andrew
Old 04-30-2013, 08:37 PM   #19
jproffer's Avatar
Rewards Points: 716
Then just do it however you want to and stop coming to this section
jproffer is online now
The Following User Says Thank You to jproffer For This Useful Post:
Speedy Petey (10-29-2015)
Old 04-30-2013, 10:37 PM   #20
I know, right? These guys are such a pain always using their spare time to give free advice to people like you who constantly ignore their good advice in favor of whatever nonsensical/dangerous conclusion they've already come to before even making their OP. Yeah, there's definitely no chance at all that you're the pain in this situation.
/sarcasm
I learn on a daily basis just perusing the discussions in this section. I don't know why it's so hard for you.
LooseSCruz is offline
The Following 2 Users Say Thank You to LooseSCruz For This Useful Post:
Jim Port (05-01-2013), Speedy Petey (10-29-2015)
Old 04-30-2013, 11:26 PM   #21
" Euro " electrician
frenchelectrican's Avatar
if you'll notice in the original post I asked which of 2 options I should take,not whether this is ok
tnx,
I will give you my option on this one .,,
The oringal 10-2 NM is not legit at all for dryer purpose due the bare conductor is not rated for current carry conductor at all.
I have see few like that before and the only way to make it legit is replace that NM cable with correct 10-3 avce ( with ) ground.
Now next question for ya if ya want to do this in correct way how far is the dryer recepetale is from the breaker box ? if a very short span it is not super hard to fish in the replacement cable however let me give you a head up the 10-3 NM cable is genrally larger than 10-2 cable will be due it will be round instead of flat so the killer will be cable staples in the wall that will stop them in track.
You may have to punch couple holes in the wall ( not very big something like 4X4 inch size useally do it in most case ) depending on which way the cable runs.
Merci,
Marc
frenchelectrican is offline
The Following User Says Thank You to frenchelectrican For This Useful Post:
Philly Master (05-01-2013)
Old 05-01-2013, 04:37 AM   #22
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,272
It is not the receptacle that was wrong in the original installation, it is the cabling method. NM cabling using the ground as the neutral was never allowed, SE cable with 2 hots and a neutral would have been the proper choice.
If the original installation had used the proper cable, A 3 wire cord could be installed on the dryer using the original receptacle.
Coastal South Carolina
rjniles is online now
Old 05-01-2013, 04:45 AM   #23
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
I think this became code in the 1999 NEC .....
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline
Old 05-01-2013, 04:50 AM   #24
dmxtothemax's Avatar
Rewards Points: 5,608
hmm...well,aren't ground and neutral tied together at the panel anyway? seems alot of hassle running a new 10/3.
Well yes they are tied together !
But if you use your existing set up (yes it will work)
If a fault developes in the neutral line (common)
then the current now takes the only other path home
thru the earth lines,
so now all exposed earthed appliances become live (nasty).
Thats why they like to keep them seperate !
Do it once !
Do it well !
dmxtothemax is offline
Old 05-01-2013, 06:37 AM   #25
jproffer's Avatar
Rewards Points: 716
And in fact, "they" are required to keep them seperate. ....but I knew what ya meant.
Old 05-01-2013, 11:35 AM   #26
Licensed electrician
Rewards Points: 1,876
We are not being a pain. There are consequences when the work is not done correctly. Some just take longer to manifest themselves. Some of the bigger ones result in a family with small children killed because someone said "I can make this work. Codes, Smodes."
I hate it when someone feels that following the code is too much hassle and ignore the rules that were put in place to protect someones life.
Jim Port is online now
Old 05-01-2013, 12:20 PM   #27
Special User
Rewards Points: 1,230
I'll bet the plug will have 4 prongs.
The dryers I've bought never come with cords -- had to buy a cord separately every time.
It's legal to put a new dryer on a 3-prong cord and -- if it's wired correctly -- use an old existing 3-prong outlet. However in your case it wasn't wired correctly, so it's a moot point and ya gotta use 10-3 and 4-prong.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline
Old 05-01-2013, 12:31 PM   #28
The receptacle shown is wired with NM cable which was not allowed to use the bare as a neutral.
Old 05-01-2013, 03:30 PM   #29
Licensed Pro
For new installations, yes. Prior to that you could use a three wires method, but only if all three conductors were insulated or SE type cable was used AND the circuit originated at the main service panel, i.e., not a sub panel.
HouseHelper is offline
The Following 3 Users Say Thank You to HouseHelper For This Useful Post:
Jim Port (05-01-2013), mm11 (05-01-2013), stickboy1375 (05-01-2013)
Old 05-01-2013, 07:04 PM   #30
A "Handy Husband"
rjniles's Avatar
Lets make sure we all help this poster in the future for the gratitude he has shown
The Following User Says Thank You to rjniles For This Useful Post:
Closed Thread
converting a 4 prong dryer outlet into a 3 prong dntbro1994 Electrical 8 07-02-2010 10:25 PM
Adding a 220v jointer to a dryer outlet popeka Electrical 7 12-13-2009 09:33 PM
Dryer outlet Davide Electrical 3 02-25-2009 11:48 AM
electric dryer - Chord and Outlet question? WILLIAM RIDGE Electrical 2 12-14-2008 09:45 PM
Running AC off of a Dryer Outlet TheCrow Electrical 7 06-16-2008 07:11 PM
