Dryer Outlet - Electrical - DIY Chatroom Home Improvement Forum
Closed Thread
Old 04-30-2013, 07:50 PM   #1
analogmusicman's Avatar
Rewards Points: 560
dryer outlet
this is my dryer outlet. probably back in '79 when the house was built, this was acceptable, but now,it's likely not,especially since I'll be putting in a new dryer and I'll bet the plug will have 4 prongs. so,tell me "sparkys",am I going to have to run a four conductor cable to the panel or can I get away with the one already there?
tnx,
analogmusicman is offline
Old 04-30-2013, 07:54 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
tnx,
That was NEVER legal.
stickboy1375 is offline
The Following 2 Users Say Thank You to stickboy1375 For This Useful Post:
mpoulton (10-29-2015), Speedy Petey (10-29-2015)
Old 04-30-2013, 07:54 PM   #3
Electrical Contractor
kbsparky's Avatar
First, that receptacle was not compliant, even back in 1979. IF you are willing to replace the wiring, use a 10/3 with a ground, and a 4-conductor receptacle (NEMA14-30R).
Second, even a new appliance can be equipped with a non-grounding 3-wire cord, which would be allowable to be used in an existing structure.
-KB
kbsparky is offline
The Following 2 Users Say Thank You to kbsparky For This Useful Post:
Old 04-30-2013, 07:55 PM   #4
kbsparky's Avatar
Agreed, however I do recall that there were some jurisdictions that allowed the use of a 10/2 cable for such installations in those days ....
-KB
kbsparky is offline
Old 04-30-2013, 07:56 PM   #5
E2 Electrician
And they were wrong.... it never should have been allowed.
The Following User Says Thank You to stickboy1375 For This Useful Post:
Old 04-30-2013, 08:07 PM   #6
Rewards Points: 560
hmm...well,aren't ground and neutral tied together at the panel anyway? seems alot of hassle running a new 10/3.
anyway,this is just another reason to believe that the builder's entire family were inspectors and let him off the hook.
Old 04-30-2013, 08:08 PM   #7
E2 Electrician
If only it were that easy...
Old 04-30-2013, 08:11 PM   #8
Rewards Points: 560
well,for me it IS that easy since I'm not licensed and have to answer to an innspector.
tnx,
Old 04-30-2013, 08:11 PM   #9
jproffer's Avatar
Rewards Points: 706
I wish...
Do some research on why they are only bonded at the main panel (or should be at least). All downstream equipment should have the ground and neutral seperated.
jproffer is offline
The Following User Says Thank You to jproffer For This Useful Post:
Nailbags (05-04-2013)
Old 04-30-2013, 08:11 PM   #10
Licensed electrician
Rewards Points: 1,478
Type NM cable was not allowed to use the bare as shown, however SE cable was.
Since this was never correct it should be fixed.
Jim Port is online now
Old 04-30-2013, 08:13 PM   #11
E2 Electrician
tnx,
why even waste everyones time in asking if its okay then?
Jim Port (05-01-2013)
Old 04-30-2013, 08:18 PM   #12
Rewards Points: 560
if you'll notice in the original post I asked which of 2 options I should take,not whether this is ok
tnx,
Old 04-30-2013, 08:20 PM   #13
jproffer's Avatar
Rewards Points: 706
Love that when people come on, ask a question, get 50 of basically the same answer (I know this particular thread didn't have 50, but some do), and then say "well, I guess I understand why I SHOULD do it the way you all suggest, but I'm not going to..."
I guess we can tell ourselves that it's a good reference for anyone searching in the future.
Still kind of annoying.
jproffer is offline
Old 04-30-2013, 08:21 PM   #14
E2 Electrician
I know, why even post the question if you dont give two ****s about the answer?
Old 04-30-2013, 08:22 PM   #15
jproffer's Avatar
Rewards Points: 706
tnx,
Either way, if you knew which option you were going to choose, why even ask the question??
jproffer is offline
Closed Thread
converting a 4 prong dryer outlet into a 3 prong dntbro1994 Electrical 8 07-02-2010 10:25 PM
Adding a 220v jointer to a dryer outlet popeka Electrical 7 12-13-2009 09:33 PM
Dryer outlet Davide Electrical 3 02-25-2009 11:48 AM
electric dryer - Chord and Outlet question? WILLIAM RIDGE Electrical 2 12-14-2008 09:45 PM
Running AC off of a Dryer Outlet TheCrow Electrical 7 06-16-2008 07:11 PM
