Dryer On The Fritz.. Wiring Problem? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-31-2007, 06:23 PM   #16
Hey again stubbie. I believe the 30 amp breaker gave out. I replaced it with an extra one i had and the voltage read fine. 220 between hots and 110 between hot and neutral. Washer and dryer still not working though so i think it may be an actual problem with the appliance itself. Washer does not seem to work at all and dryer only works when the washer is set to a certain setting for some reason. Maybe the lack of correct flow with the #14 burned something out.... any ideas? if not thank you so much for all the help you provided.
cisco10 is offline   Reply With Quote
Old 08-31-2007, 07:57 PM   #17
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Has anybody been fooling with the wires that connect to the terminal block of the appliance? Or any other place?
Just to let you know.... a 4 wire dryer circuit (H-H-N-Grd) is required to be code compliant in your particular situation, I'm not sure if that is what you did if you bought 10/3 G and kept the 10-30R. You need a 14-30R and a change at the dryer/washer terminal block as mentioned earlier. This has nothing to do with your problem however. assuming that everything is wired correctly. Did this dryer /washer work before you moved it to the new location?
Stubbie
Old 11-19-2009, 02:26 PM   #18
Stubbie, can you help me now? can I email you? see my post
cawlady is offline   Reply With Quote
Dryer problem blmacias Electrical 21 06-14-2007 08:15 PM
Problem with ELECTRIC DRYER plugs SpaceCrawler Appliances 6 06-03-2007 11:21 AM
Dryer wiring jasjks Electrical 8 09-11-2006 05:33 PM
wiring for a dryer irish_hood Electrical 4 01-11-2006 02:27 PM
