#1 |
Dryer Circuit
My house was built around 1985 and the dryer circuit is 3-wire. The cable that was used is a black NM cable labeled "10/3" but doesn't say anything about a ground. However, I opened up the dryer receptacle box and I can see paper like the type used to insulate the ground wire in NM cables. Could it be that the ground was snipped at installation since it wasn't required?
By the way, it's a round shaped NM cable like most 3 wire + ground cables are. |
#2 |
Dryer Circuit
Possible make sure you shut breaker OFF when you check.Also might find the wire in the Electrical Panel and trace the ground down (Shut OFF Main )
#3 |
Dryer Circuit
It would say 10/3 "w/g" (with ground)
I have seen old 10/3 round cable with no ground. |
#4 |
Dryer Circuit |
#5 |
Dryer Circuit
To piss off electricians.
![]() It's part of the mfg process. |
#6 |
Dryer Circuit |
#7 |
Licensed Pro
Dryer Circuit
Because that was the proper way to wire a dryer, with three insulated conductors.
"Life is hard. Life is harder when you're stupid." John Wayne |
#8 |
Xtreme DIY'r
Dryer Circuit
Older wire had paper around everything
| Display Modes | |
| Wiring in New Addition? | sandyman720 | Electrical | 6 | 11-27-2011 04:34 PM |
| Tripping breakers,neutrals,120 volts and 240 volts OH My!!! | Stubbie | Electrical | 17 | 06-11-2011 07:09 AM |
| Wiring a single pole switch into a 220v circuit | rlmorgan | Electrical | 38 | 10-15-2008 08:59 PM |
| dryer & stove sharing circuit? | teamSpatula | Electrical | 9 | 09-16-2008 03:59 PM |
| So lost - electrical requirements please help | lapsis9 | HVAC | 4 | 12-20-2006 09:09 PM |
