-   -   Dryer Circuit (http://www.diychatroom.com/f18/dryer-circuit-51030/)
kornbln 08-16-2009 07:01 PM
Dryer Circuit
My house was built around 1985 and the dryer circuit is 3-wire. The cable that was used is a black NM cable labeled "10/3" but doesn't say anything about a ground. However, I opened up the dryer receptacle box and I can see paper like the type used to insulate the ground wire in NM cables. Could it be that the ground was snipped at installation since it wasn't required?
By the way, it's a round shaped NM cable like most 3 wire + ground cables are.
300zx 08-16-2009 07:13 PM
Possible make sure you shut breaker OFF when you check.Also might find the wire in the Electrical Panel and trace the ground down (Shut OFF Main )
220/221 08-16-2009 07:26 PM
It would say 10/3 "w/g" (with ground)
I have seen old 10/3 round cable with no ground.
kornbln 08-16-2009 07:53 PM
What's the paper for?
220/221 08-16-2009 07:55 PM
To piss off electricians.:laughing:
It's part of the mfg process.
kornbln 08-16-2009 07:56 PM
Hmm, I've only ever seen it wrapped around the bare ground. Why would it be in 10/3 w/o ground?
HouseHelper 08-16-2009 08:56 PM
Because that was the proper way to wire a dryer, with three insulated conductors.
Scuba_Dave 08-16-2009 08:58 PM
Older wire had paper around everything :(
kornbln 08-16-2009 10:07 PM
I meant why does it have paper without a ground?
