Dryer Adapters - Electrical - DIY Chatroom Home Improvement Forum
Old 09-23-2012, 04:00 PM   #1
dryer adapters
can i buy an adapter that would change my 5-20r receptical to an 14-30p so i can plug my dryer in?
needsmydryer is offline   Reply With Quote
Old 09-23-2012, 04:24 PM   #2
Code05's Avatar
Rewards Points: 1,104
You want to plug a machine that needs a 30 amp 240 volt receptacle into a 20 amp 120 volt receptacle?
Are you crazy??????
Code05 is offline   Reply With Quote
Old 09-23-2012, 04:45 PM   #3
Rewards Points: 13,994
Is this a 110 volt or a 220 volt dryer?
Old 09-23-2012, 05:23 PM   #4
its 220v
Old 09-23-2012, 05:30 PM   #5
I dont think such a thing would exist.
You existing receptacle is rated for 20 amps at most, which means the breaker and the wire feeding are likely also rated for 20 amps max. It also needs 120v. The receptacle you want to change too needs 240v. Quite simply, you need 1 more wire and all the wires need to be a bigger size.
AltaSparky is offline   Reply With Quote
Old 09-23-2012, 05:54 PM   #6
thank you for explaining that to me, instead of just asking if i was crazy. i dont know a thing about the subject.
Old 09-23-2012, 06:16 PM   #7
Rewards Points: 512
Deleted
Old 09-23-2012, 06:19 PM   #8
Rewards Points: 512
Can you take a pic of your receptacle and plug, and upload it here?
Old 09-23-2012, 06:19 PM   #9
Rewards Points: 1,192
You will need a new 30 amp 4 wire circuit and make sure the dryer is hooked uped to a 4 wire config.
bobelectric is offline   Reply With Quote
The Following User Says Thank You to bobelectric For This Useful Post:
Code05 (09-23-2012)
Old 09-23-2012, 06:42 PM   #10
Code05's Avatar
Those are NEMA receptacles designations in the OP.
Here is a chart:
The Following User Says Thank You to Code05 For This Useful Post:
sirsparksalot (09-23-2012)
Old 09-23-2012, 06:49 PM   #11
Rewards Points: 512
yeah, I know, Code5. I was just trying to see if OP actually knew what they had.
Old 09-23-2012, 06:55 PM   #12
Code05's Avatar
Oops, sorry.
Strange, OP could site those specs and not know that his question would not work.
Another Dryer Question 3 to 4 wire John3rd Electrical 15 07-29-2015 01:10 PM
DRYER HELP or Bigger Problem? SitEatChat Electrical 19 05-05-2012 01:12 AM
Under counter washer / dryer installation wstt Plumbing 0 04-10-2012 11:00 AM
Help with Electric 240v for a Dryer Sunshine807 Electrical 17 10-21-2011 10:35 AM
Dryer Venting Question cbzdel HVAC 4 05-18-2011 02:16 PM
