-   -   dryer is 27 amps on 30 amp breaker (http://www.diychatroom.com/f18/dryer-27-amps-30-amp-breaker-100104/)
whatrymes 03-30-2011 08:45 PM
I was just reading today about plug-in appliances should not exceed 80% of a circuit's rating. Going over my stuff, I noticed our dyer's plate says "Motor 4 amps; Heater and accessories 23 amps." I assume they are added together which would be 27 amps and at 125% thats 33.5 amps. I've never had a problem with operation.
What do you suggest??
frenchelectrican 03-30-2011 08:55 PM
I will not worry too much with the heating part due it will cycle depending on the thermosat setting so it will cycle so it will not be a constant load at all.
Merci.
Marc
Bigplanz 03-30-2011 09:30 PM
38 Attachment(s)
I was trouble shooting a tripping breaker on my dryer and put an ammeter on both legs of the 240V circuit. What I discovered was that when just the blower is running one leg drew 4 amps and the other drew nothing, since the blower is 120V. When the heating element was on, one side drew 27 amps and the other 23 amps. My breaker was bad and replacing it solved my problem. What you describe is normal.
