Dryer 220 Switch Could I Use For Stove - Electrical - DIY Chatroom Home Improvement Forum
Old 03-06-2009, 10:30 PM   #1
Dryer 220 switch Could I use for stove
Hi Pros,
In my Basement I got dryer now we are planning to buy new stove for basement instead of doing wiring for stove I was thinking about using the same switch for stove as well coz the both are side by side.Now if any one suggest that do a wiring from the box so that is not possible.
Question is if there is any circuit box where I could plug both and switch back and forth.Does it make sence excuse me I am very new but like to learn.If so then suggest me the rightway.thkxs
haroonsj is offline   Reply With Quote
Old 03-06-2009, 10:34 PM   #2
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Originally Posted by haroonsj View Post
Hi Pros,
Welcome,
Where are you from?
Yes, I think I understand what your asking, while there maybe a way to accomplish this, it is very likely much easier (also cheaper, and possibly safer) to run new wires back to your main panel and install a new outlet for the oven.
Jamie
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 03-06-2009, 11:06 PM   #3
My dryer is 30a 240v, my stove is 50a 240v
In my case not possible
Depends upon the wire, breaker, stove & dryer requirements
Old 03-06-2009, 11:41 PM   #4
Originally Posted by jamiedolan View Post
Welcome,
Where are you from?
Jamie
Thkx Jamie,for the answer.I know that very well but I like to know is there is any other way coz there is no space left in my Panel for 220.I used all.
I am attaching a picture of a panel where stove and dryer connected all the time when I need to use dryer just move the switch toward dryer and wiseversa.what you think does it make sence
Could you tell me if there is any thing like here or should I ask my Electrician to make it for me or I could go to Home hardware to get it.thkxs
Old 03-06-2009, 11:53 PM   #5
What is the rating of the Stove?? Usually these are 40a-50a
Is it a free standing range?
What is the current breaker & wire for the dryer?
The picture is worthless without the stove & dryer power requirements
There isn't any pre-made switch really, this would need to be wired
Unless the dryer & stove use the same power this will NOT work
You could take out the dryer breaker, install a larger breaker & run a small sub-panel. Then add 2 breakers & runs for the dryer & stove
Old 03-07-2009, 08:12 AM   #6
Master Electrician
JohnJ0906's Avatar
A relatively cheap and simple solution.
However, I would move lighting circuits instead. Less load on the sub-panel, and leaves the range and dryer (heavier loads) in the main panel.
John from Baltimore
One Day at a Time
"Experience is what you get when you were expecting something else"
"The bitterness of low quality lingers long after the sweetness of low cost is forgotten"
JohnJ0906 is offline   Reply With Quote
single gang single pole switch on fan fabian Electrical 14 03-05-2009 02:11 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 07:14 PM
old wire, backfed switch question Jack A. Trades Electrical 6 07-03-2008 12:05 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 03:53 PM
