Dryer On A 220 Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 10-10-2011, 11:59 AM   #1
dryer on a 220 outlet
i have a new dryer on a 220 outlet..and after about a month of it working fine, the circuit breaker started switching off after a few min..now i can't run my dryer for more then a few min before the breaker switches off. please help.
bigbadborders is offline   Reply With Quote
Old 10-10-2011, 12:21 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 224
Could be a bad heating element in the dryer, or loose connections at the receptacle, or loose connections on the plug, or loose connections on the breaker, or a bad breaker.
Where do you want to start?
Old 10-10-2011, 02:39 PM   #3
Semi-Pro Electro-Geek
Rewards Points: 2,892
I would bet on loose connections at the breaker. Loose connections anywhere else should not cause this problem. A bad dryer element can though, if it shorts to itself or the chassis. Check the connections at the circuit breaker.
mpoulton is offline   Reply With Quote
Water damage in laundry room re: clothes dryer outlet mcbutterpants Electrical 3 02-07-2011 10:33 PM
Electric range in dryer outlet Greenlevel Electrical 5 02-03-2011 06:20 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 06:13 PM
Use Dryer Outlet for Woodworking Tools mikewrobel Electrical 7 08-02-2009 12:01 PM
Clothes Dryer / Outlet homercavazos Electrical 8 10-30-2007 05:14 PM
