Dryer - Electrical - DIY Chatroom Home Improvement Forum
Old 08-12-2012, 04:47 PM   #1
amy212's Avatar
dryer
How high does a dryer outlet have to b from the ground?
amy212 is offline   Reply With Quote
Old 08-12-2012, 04:50 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Anywhere you want, just avoid the dryer duct. A stacked unit may require the receptacle be higher than normal.
Old 08-12-2012, 04:51 PM   #3
Electrical Contractor
kbsparky's Avatar
Is your dryer located outside? Sitting on dirt?
I've seen many installations where the dryer outlet is mounted on the floor!
Just ensure that the cord will reach the outlet!
-KB
Old 08-12-2012, 04:53 PM   #4
E2 Electrician
I have a feeling this thread is going to get a lot of hits.
The Following User Says Thank You to stickboy1375 For This Useful Post:
amy212 (08-12-2012)
Old 08-12-2012, 05:01 PM   #5
amy212's Avatar
Its on a slab just didnt know if there was a required height
Old 08-12-2012, 05:04 PM   #6
kbsparky's Avatar
Not really. Unless you are in a flood plain, then the rules are changed.
-KB
Old 08-12-2012, 05:05 PM   #7
amy212's Avatar
Ok thanks
Old 08-12-2012, 05:22 PM   #8
Master Electrician
This made me laugh out loud.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
The Following User Says Thank You to andrew79 For This Useful Post:
stickboy1375 (08-12-2012)
Old 08-12-2012, 05:59 PM   #9
amy212's Avatar
Only 2 lol .....
Old 08-12-2012, 06:07 PM   #10
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
You'll have to excuse them, it's pretty much a sausage fest round here.
Old 08-12-2012, 06:07 PM   #11
Rewards Points: 1,192
4 foot to center..
bobelectric is offline   Reply With Quote
Old 08-12-2012, 06:27 PM   #12
Master Electrician
Originally Posted by bobelectric
4 foot to center..
Wouldn't that put it above some dryers?
Code reference?
Old 08-12-2012, 07:07 PM   #13
E2 Electrician
Code reference?
He wasn't stating a code, just an opinion, I put them at that height at times.
Old 08-12-2012, 07:40 PM   #14
Idiot Emeritus
Rewards Points: 1,492
I put dryer outlets at 48", right next to the washer outlet. And I also center it at 30" from the wall, a typical dryer is 28" wide, this way the cord is not jammed behind the dryer.
I also box out the stud bay behind the center of the dryer, from the floor to about 1' or so, this is where the vent is stubbed. This way the hose can be recessed in the wall and the dryer can be pushed all the way back to the wall.
Rob
micromind is offline   Reply With Quote
Old 08-12-2012, 07:48 PM   #15
amy212's Avatar
Ok thanks guys 4 ur help ..... im starting 2 redo my kitchen tomorrow so im sure ill b full of stupid questions 4 ya 2 answer
Another Dryer Question 3 to 4 wire John3rd Electrical 15 07-29-2015 01:10 PM
DRYER HELP or Bigger Problem? SitEatChat Electrical 19 05-05-2012 01:12 AM
Under counter washer / dryer installation wstt Plumbing 0 04-10-2012 11:00 AM
Help with Electric 240v for a Dryer Sunshine807 Electrical 17 10-21-2011 10:35 AM
Dryer Venting Question cbzdel HVAC 4 05-18-2011 02:16 PM
