-   -   dryer (http://www.diychatroom.com/f18/dryer-153443/)
amy212 08-12-2012 04:47 PM
dryer
How high does a dryer outlet have to b from the ground?
stickboy1375 08-12-2012 04:50 PM
12 Attachment(s)
Anywhere you want, just avoid the dryer duct. A stacked unit may require the receptacle be higher than normal.
kbsparky 08-12-2012 04:51 PM
Is your dryer located outside? Sitting on dirt?
I've seen many installations where the dryer outlet is mounted on the floor!
Just ensure that the cord will reach the outlet! :whistling2:
stickboy1375 08-12-2012 04:53 PM
12 Attachment(s)
I have a feeling this thread is going to get a lot of hits. ;)
amy212 08-12-2012 05:01 PM
Its on a slab just didnt know if there was a required height
kbsparky 08-12-2012 05:04 PM
Not really. Unless you are in a flood plain, then the rules are changed.
amy212 08-12-2012 05:05 PM
Ok thanks
andrew79 08-12-2012 05:22 PM
This made me laugh out loud.
amy212 08-12-2012 05:59 PM
Only 2 lol .....
k_buz 08-12-2012 06:07 PM
You'll have to excuse them, it's pretty much a sausage fest round here.
bobelectric 08-12-2012 06:07 PM
4 foot to center..
andrew79 08-12-2012 06:27 PM
Originally Posted by bobelectric
4 foot to center..
Wouldn't that put it above some dryers?
Code reference?
stickboy1375 08-12-2012 07:07 PM
12 Attachment(s)
Code reference?
He wasn't stating a code, just an opinion, I put them at that height at times.
micromind 08-12-2012 07:40 PM
I put dryer outlets at 48", right next to the washer outlet. And I also center it at 30" from the wall, a typical dryer is 28" wide, this way the cord is not jammed behind the dryer.
I also box out the stud bay behind the center of the dryer, from the floor to about 1' or so, this is where the vent is stubbed. This way the hose can be recessed in the wall and the dryer can be pushed all the way back to the wall.
Rob
amy212 08-12-2012 07:48 PM
Ok thanks guys 4 ur help ..... im starting 2 redo my kitchen tomorrow so im sure ill b full of stupid questions 4 ya 2 answer ;)
