Drop Wire (From Weatherhead to Meter)
Why is it that there are all of these people thinking that they can all of a sudden do a licensed skilled electrician job, such as swapping out every piece from a drop to the main panel. I am in the process to bid out changing a main panel, due to I do not want to deal with all of the headaches, when I can have a local company do the main panel change out, pull the meter in one cal, with minimal costs.
Too many people do not realize the huge amount that it can cost when you have to change out the drop, meter pan, meter, main breaker panel, re-hook up all branch circuits inside the home, in some ahj's, having to pull a permit, inspection, post-inspection, etc.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
