Drop In Range Hook-Up - Electrical - DIY Chatroom Home Improvement Forum
Old 04-08-2007, 05:40 PM   #1
I have a drop in range that was hard-wired. I want to now use it in a kitchen island/cart that I can move about on occassion. I want to install a plug and use a wall mounted receptacle. The data sheet says: "The range must be connected to a grounded metal, permanent wiring system." Can I add a plug to this unit or does the range need to be hard-wired. I'll have an electrician do the work, but I don't want to go to the trouble of building a cabinet for the range if I can't use a plug. Any advise?
mickey45 is offline   Reply With Quote
Old 04-08-2007, 09:29 PM   #2
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Arent you the resourceful one,.... I suppose one could argue that the cooktop was not engineered for cord and plug by the manufacturer. But I suppose if you used a receptacle rated for the load (amps) there could be a lot worst things. You would also have to make sure the wiring to the receptacle was appropriate for the cooktop.
Stubbie
gas range swap kenny11876 Appliances 2 02-20-2008 08:31 PM
Range outlet required? Doug_Shaver Electrical 2 06-12-2007 05:10 PM
Home, home and the range! ...A dimensional query. Hushpuppy Carpentry 4 05-26-2006 06:23 PM
Can I Wire a range hood to an exhisting outlet? skellies Electrical 2 05-09-2006 04:06 PM
Replacing Stove Top with Range the.vicster Electrical 3 02-23-2006 05:12 PM
