Drilling Sideways Through Multiple Studs In A Finished Wall? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-30-2010, 10:35 AM   #1
Drilling sideways through multiple studs in a finished wall?
Is it possible without removing a strip of plaster? Is there some super secret pro technique that someone can tell me or are my only options to go in from the top or bottom, or remove a strip of plaster along the horizontal path that my cable is going to take?
jerseyguy1996 is offline   Reply With Quote
Old 12-30-2010, 11:04 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
I use a pistol grip drill and stubby spade bits for one or 2 holes.
Any more than that and I pull a strip of wall.
Old 12-30-2010, 11:11 AM   #3
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,374
If there is baseboard trim, you could remove it and remove the plaster under that to get at the studs. Still a lot of work but the finish will be cleaner.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 12-30-2010, 11:55 AM   #4
Rewards Points: 246
Go down or up. Below or above. Cutting up walls is only an option when there is no other option.
Old 12-30-2010, 12:01 PM   #5
I kind of thought that that was probably the case. I guess I will be going through the top or bottom.
Old 12-30-2010, 12:22 PM   #6
There are flexible drill bits. 4' long, different diameters. Using one of these, you start in a hole and drill sideways, and then when you get to the end, you buy the 4' extension. ook at Home Depot in the electrical section. Make sure you tie the string on *before* you pull the bit out of the wall. (Bit has a hole in the end for this)
JPraski is offline   Reply With Quote
The Following User Says Thank You to JPraski For This Useful Post:
Thurman (01-01-2011)
Old 12-30-2010, 04:03 PM   #7
Scared Electrician
Saturday Cowboy's Avatar
the Flexbits take a little bit of skill to use but are the better option IMHO.
Saturday Cowboy is offline   Reply With Quote
Old 12-31-2010, 07:55 AM   #8
Do work
Rewards Points: 81
Thats how I do it too.
liquidvw is offline   Reply With Quote
Old 12-31-2010, 10:52 PM   #9
iminaquagmire's Avatar
Rewards Points: 338
If you cant go above or below, use this trick. The baseboard option works on tall trims but not low ones. Plus its a lot of risk on trims that aren't stock moldings. Get yourself a 4 or 5" hole saw. You're going to drill a hole centered on each stud. Saw out the drywall. Save the plug. Use a spade bid or forstner bit to make a notch in the stud. Run wire across stud in notch. Cover notches with nail plates, and then glue or screw the drywall plug back in the hole. Use some paintable silicone in the kerf gap, then skim with some compound. Its not something you'd want to do to rewire a house but for say putting in wall sconces it works great.
iminaquagmire is offline   Reply With Quote
The Following 3 Users Say Thank You to iminaquagmire For This Useful Post:
ControlTech (01-02-2011), jerseyguy1996 (01-01-2011), Thurman (01-01-2011)
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Drilling through metal studs plus4dbu Building & Construction 6 01-24-2009 08:37 PM
Foyer wall finished TheVampire Project Showcase 2 09-02-2008 09:40 AM
Window frame not flush with finished wall Stubbie Carpentry 9 06-24-2008 02:38 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
