Drilling Holes Through Studs - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-20-2009, 08:31 AM   #16
Chicago, IL
Michael Thomas's Avatar
- http://www.canyonco.org/dsd.aspx?id=8822
Home Inspection: "A business with illogically high liability, slim profit margins and limited economies of scale. An incredibly diverse, multi-disciplined consulting service, delivered under difficult in-field circumstances, before a hostile audience in an impossibly short time frame, requiring the production of an extraordinarily detailed technical report, almost instantly, without benefit of research facilities or resources." - Alan Carson
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 05-20-2009, 11:52 AM   #17
very good info, thanks guys!
paul_arc is offline   Reply With Quote
Old 05-20-2009, 05:23 PM   #18
Electrical Contractor
kbsparky's Avatar
Originally Posted by paul_arc View Post
Im adding a sub panel and need to run a 1 1/4" conduit.....It would probably need to be drilled 1 1/2" size....
You will need a minimum 1-3/4" hole size to accommodate a 1" trade size conduit.
If you are installing PVC conduit, then a 2" hole is required for any couplings to pass through.
Drilling through metal studs plus4dbu Building & Construction 6 01-24-2009 09:37 PM
Drilling into metal studs, do they flex? thubbard Building & Construction 5 01-15-2009 02:19 PM
Engineering help request: drilling holes in a deck joist, supported by a post Deck Building & Construction 14 05-31-2008 11:16 PM
drilling vent holes ape Roofing/Siding 4 10-15-2007 05:36 PM
Drilling through multiple studs dailo Carpentry 7 10-05-2007 09:17 PM
