Drilling Holes Through Studs - Electrical - DIY Chatroom Home Improvement Forum
Old 05-19-2009, 01:57 PM   #1
Drilling holes through studs
Im adding a sub panel and need to run a 1 1/4" conduit. I would like to put the conduit in the wall but wondering what is the maximum size hole that I can drill through the studs. It would probably need to be drilled 1 1/2" size and have to drill about 6 studs. I can run it surface if needed but would like to put it inside the wall.
Whats the max size I can drill through the studs?
paul_arc is offline   Reply With Quote
Old 05-19-2009, 02:53 PM   #2
If it's not a bearing wall, I wouldn't be concerned. You still have an inch on each side left.
Think about steel studs. They have 1bout 1 1/2 inch holes punched in them every couple feet.
Technically, I don't know the answer.
220/221 is offline   Reply With Quote
Old 05-19-2009, 02:58 PM   #3
Thats exactly what I was thinking also, "technically" I dont know the answer either
Old 05-19-2009, 03:31 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
40% allowed in bearing walls and 60% allowed in non-bearing walls.
For a 2x4 this is 1-7/16" or 2-1/8"
Either way you will need nail plates on BOTH sides of every stud.
Old 05-19-2009, 04:18 PM   #5
Bigplanz's Avatar
Rewards Points: 916
I believe you, so don't take this question the wrong way. Could you provide a code citation? This is really good information, and I would like to be able to tell people this and back it up. Thanks, sincerely.
Bigplanz is offline   Reply With Quote
Old 05-19-2009, 05:52 PM   #6
Registered User
Rewards Points: 4,912
Look at wall framing here:
http://www.codecheck.com/cc/pg03_04building.html
Be safe, G
Old 05-19-2009, 06:11 PM   #7
I have this Wood Boring Guide .pdf file. It is from:
Western Wood Products Association
522 SW Fifth Avenue Suite 400
Portland, OR 97204-2122
503/224-3930 Fax: 503/224-3934
e-mail: info@wwpa.org
web site: http://www.wwpa.org
I don't remember where I got it but you can try it here: http://www2.wwpa.org/Portals/9/docs/PDF/A11.pdf
I had to join their site to see if it was still available. It is but you may have to join (for free).
Old 05-19-2009, 06:24 PM   #8
Bigplanz's Avatar
Rewards Points: 916
Thank you very much.
Old 05-19-2009, 07:21 PM   #9
Did the .pdf link work for you?
Old 05-19-2009, 07:49 PM   #10
Rewards Points: 150
Send a message via AIM to Bocolo
Speedy, the pdf works. Very good info. Thanks.
One Pound of Knowledge Requires Ten Pounds of Common Sense In Order To Be Useful
Bocolo is offline   Reply With Quote
Old 05-19-2009, 07:49 PM   #11
Bigplanz's Avatar
Rewards Points: 916
Yes, it did. Very interesting reading. Thanks.
Old 05-19-2009, 08:35 PM   #12
Chicago, IL
Michael Thomas's Avatar
- http://www.canyonco.org/dsd.aspx?id=8823
____________
Home Inspection: "A business with illogically high liability, slim profit margins and limited economies of scale. An incredibly diverse, multi-disciplined consulting service, delivered under difficult in-field circumstances, before a hostile audience in an impossibly short time frame, requiring the production of an extraordinarily detailed technical report, almost instantly, without benefit of research facilities or resources." - Alan Carson
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 05-19-2009, 08:53 PM   #13
IRC R602.6
Same info. Perfect reference Michael. Thanks.
Old 05-19-2009, 09:27 PM   #14
Do you have a drawing like that for floor/ceiling joists?
Old 05-20-2009, 06:39 AM   #15
In that .pdf I linked above.
Drilling through metal studs plus4dbu Building & Construction 6 01-24-2009 09:37 PM
Drilling into metal studs, do they flex? thubbard Building & Construction 5 01-15-2009 02:19 PM
Engineering help request: drilling holes in a deck joist, supported by a post Deck Building & Construction 14 05-31-2008 11:16 PM
drilling vent holes ape Roofing/Siding 4 10-15-2007 05:36 PM
Drilling through multiple studs dailo Carpentry 7 10-05-2007 09:17 PM
