-   -   Drilling holes through studs (http://www.diychatroom.com/f18/drilling-holes-through-studs-44798/)
paul_arc 05-19-2009 12:57 PM
Im adding a sub panel and need to run a 1 1/4" conduit. I would like to put the conduit in the wall but wondering what is the maximum size hole that I can drill through the studs. It would probably need to be drilled 1 1/2" size and have to drill about 6 studs. I can run it surface if needed but would like to put it inside the wall.
Whats the max size I can drill through the studs?
220/221 05-19-2009 01:53 PM
If it's not a bearing wall, I wouldn't be concerned. You still have an inch on each side left.
Think about steel studs. They have 1bout 1 1/2 inch holes punched in them every couple feet.
Technically, I don't know the answer. :jester:
paul_arc 05-19-2009 01:58 PM
Thats exactly what I was thinking also, "technically" I dont know the answer either:huh:
Speedy Petey 05-19-2009 02:31 PM
40% allowed in bearing walls and 60% allowed in non-bearing walls.
For a 2x4 this is 1-7/16" or 2-1/8"
Either way you will need nail plates on BOTH sides of every stud.
Bigplanz 05-19-2009 03:18 PM
38 Attachment(s)
I believe you, so don't take this question the wrong way. Could you provide a code citation? This is really good information, and I would like to be able to tell people this and back it up. Thanks, sincerely.
Gary in WA 05-19-2009 04:52 PM
Look at wall framing here:
http://www.codecheck.com/cc/pg03_04building.html
Be safe, G
Speedy Petey 05-19-2009 05:11 PM
I have this Wood Boring Guide .pdf file. It is from:
Western Wood Products Association
522 SW Fifth Avenue Suite 400
Portland, OR 97204-2122
503/224-3930 Fax: 503/224-3934
e-mail: info@wwpa.org
web site: http://www.wwpa.org
I don't remember where I got it but you can try it here: http://www2.wwpa.org/Portals/9/docs/PDF/A11.pdf
I had to join their site to see if it was still available. It is but you may have to join (for free).
Bigplanz 05-19-2009 05:24 PM
38 Attachment(s)
Thank you very much.
Speedy Petey 05-19-2009 06:21 PM
Did the .pdf link work for you?
Bocolo 05-19-2009 06:49 PM
Speedy, the pdf works. Very good info. Thanks.
Bigplanz 05-19-2009 06:49 PM
38 Attachment(s)
Yes, it did. Very interesting reading. Thanks.
Michael Thomas 05-19-2009 07:35 PM
http://www.canyonco.org/assets/0/74/...e426.jpg?n=947
- http://www.canyonco.org/dsd.aspx?id=8823
____________
Home Inspection: "A business with illogically high liability, slim profit margins and limited economies of scale. An incredibly diverse, multi-disciplined consulting service, delivered under difficult in-field circumstances, before a hostile audience in an impossibly short time frame, requiring the production of an extraordinarily detailed technical report, almost instantly, without benefit of research facilities or resources." - Alan Carson
Speedy Petey 05-19-2009 07:53 PM
IRC R602.6
Same info. Perfect reference Michael. Thanks.
220/221 05-19-2009 08:27 PM
Do you have a drawing like that for floor/ceiling joists?
Speedy Petey 05-20-2009 05:39 AM
In that .pdf I linked above.
