Old 03-22-2008, 11:23 PM   #1
MJT
Drilling accident
I was in the process of drilling through one of my garage walls and nicked one of my electrical lines coming from my panel. . When I hit it, it sparked and blew the wires in half. This is a 120 circuit, Can I splice the wiring or do I need to re-feed the circuit?
MJT is offline   Reply With Quote
Old 03-22-2008, 11:28 PM   #2
nap
You talking to me?
nap's Avatar
Drilling accident
all splices must be in a junction box. the problem is the cable is now too short so you have to figure out how to repull one side of the cable or install 2 boxes and a new piece of cable between them.
Old 03-23-2008, 12:11 PM   #3
Res Ipsa Loquitur
Drilling accident
New way of sharpening drill bits?
If you have easy access either to the panel or next junction you can place a junction box at the shorted area (leaving enough wire available to splice) then rewire to the panel or junction box whichever is closer/easier. The box must be maintained accessible. Use a blank cover as necessary.
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Drilling into metal studs, do they flex? thubbard Building & Construction 5 01-15-2009 02:19 PM
drilling holes for posts and stakes amakarevic Building & Construction 18 01-18-2008 12:54 PM
Drilling through concrete mpiercewa Building & Construction 6 10-10-2007 08:16 PM
drilling repirator? martinlw2000 Safety 11 08-21-2007 04:05 PM
Drilling into Center Beam leted_82 Building & Construction 2 03-06-2007 09:52 PM
