Old 01-17-2009, 11:01 AM   #1
DIY'er
jamiedolan's Avatar
Drawing of where kitchen outlets need to be
I am looking for that drawing / diagram that shows the required placement of kitchen counter top outlets. I have been unable to locate it, even thought I know I've see it posted here before. If anyone know what I am talking about about would be so kind as to post it. Thank You.
Jamie
Jamie Dolan - Neenah, WI
Need Help Uploading Photos?
jamiedolan is offline   Reply With Quote
Old 01-17-2009, 12:55 PM   #2
dSilanskas's Avatar
I know there is a drawing in the code book but its very simple to be honest. You need at least two circuits for kitchen counter top plugs. You have to have a receptacle within two feet of a sink and you must have a receptacle maximum 24" from eachother
dSilanskas is offline   Reply With Quote
Old 01-17-2009, 01:29 PM   #3
Licensed Pro
You need two 20A circuits, minimum; spacing is 48" maximum; any countertop 12" or wider needs a receptacle; all countertop receptacles need to be GFCI protected. There is more, but those are some basics.
Old 01-17-2009, 02:16 PM   #4
Xtreme DIY'r
Is this the diagram? Saw it the other day & saved it
Old 01-17-2009, 02:37 PM   #5
Home Depot sells this book, Electrical Code Simplified, (house wiring guide) here in Canada its $13.95. The latest version is good from 2007 untill 2010. It mentions that in the future all above counter recepticles will probably need to be GFCI protected but that as per code now (Ontario) only the two on opposite sides of the sink need to be. I recommend this book highly! It has great detail, and includes a broad range of wiring situations and layouts. Good Luck.
Did it myself is offline   Reply With Quote
Old 01-17-2009, 04:15 PM   #6
DIY'er
jamiedolan's Avatar
Thank you dave very much for the drawing. Thank you everyone else also. I really wanted a drawing just like this to show my dad to help him understand where the outlets need to go. He was having trouble seeing why he needed an extra outlet on one of his counters.
Thanks again
Jamie
Old 01-17-2009, 04:31 PM   #7
joed's Avatar
Originally Posted by dSilanskas View Post
You need at least two circuits for kitchen counter top plugs. You have to have a receptacle within two feet of a sink and you must have a receptacle maximum 24" from each other
Not quite correct.
The code says that any spot on the counter wall space can not be more than 24" from a receptacle. That means a receptacle within 24" of the end of the counter and then every 48" along counter. The middle of 48" is 24" from a receptacle either way.
Any counter section 12" or longer needs a receptacle.
Old 01-27-2009, 02:45 PM   #8
just curious as to why these rules are as they are. Is it so people don't use a lot of extension cords to get to the outlets?
Typ0 is offline   Reply With Quote
Old 01-27-2009, 02:57 PM   #9
Moderator
Termite's Avatar
Exactly. Stringing cords across wet areas and stoves and walking surfaces can get people hurt.
Old 01-27-2009, 08:04 PM   #10
joed's Avatar
And because the devices commonly used in the kitchen(toaster, microwave, coffee pot, etc) are high current devices.
Old 01-27-2009, 08:07 PM   #11
" Euro " electrician
frenchelectrican's Avatar
Now you know why the kitchen appliance manufacters did make short cords on purpose Due the Code requirement.
{ the code is about the same in both North America and France so there is not much diffrence there }
Merci,Marc
Old 01-27-2009, 08:29 PM   #12
I've always heard the french don't like us. I'm surprised they use our electrical code.
DISQUALIFIER: I know I'm new here and you all don't know my sense of humor. That is a deep and good historical joke . If I can say that about myself.
Merci,Marc
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 01:29 PM
Power leading to outlets but no power ? s_anthony Electrical 22 01-05-2009 02:08 PM
kitchen countertop outlets, opposite from sink amakarevic Electrical 6 10-19-2008 04:33 PM
outlets work, but barely (?) joeyboy Electrical 7 08-27-2008 09:37 AM
tiling kitchen...how to deal with electrical outlets in floor? tarheelblue Electrical 4 01-29-2008 11:40 PM
