Old 11-10-2012, 03:09 PM   #1
Drain in conduit at bottom of service panel?
I would like to add a new conduit from my outdoor breaker panel to the inside of my crawlspace, however the only knockouts still available are in the bottom of the box. Do I need to have a drain in the conduit? I was planning on using a 2ft section of liquidtight conduit to go from the outdoor panel to a new j-box in the crawlspace.
d_jimgreen is offline   Reply With Quote
Old 11-10-2012, 03:32 PM   #2
Code05's Avatar
2011 NEC
225.22 Raceways on Exterior Surfaces of Buildings or
Other Structures. Raceways on exteriors of buildings or
other structures shall be arranged to drain and shall be
suitable for use in wet locations.
Code05 is offline   Reply With Quote
The Following User Says Thank You to Code05 For This Useful Post:
d_jimgreen (11-10-2012)
Old 11-10-2012, 05:59 PM   #3
What should I search for to find an acceptable drain fitting? All I have found so far is explosion proof drain/vent fittings. I assume drilling a hole in the bottom of a conduit body isn't a listed method.
Old 11-10-2012, 06:03 PM   #4
Licensed Electrician
k_buz's Avatar
The coduit body is the drain.
Location...Location...Location
Tags
drain conduit
Questions about 100-200A service upgrade kwilcox Electrical 35 04-22-2012 06:15 PM
Section 310.15(B)(6) vs. 210.4. Don't assume, call your friendly AHJs! Daneel Electrical 3 04-11-2012 08:24 AM
Service move - old panel, separating neutral and ground WillK Electrical 3 06-17-2011 09:18 AM
New service Help (Meter can/ service mast Conduit help) cwolford Electrical 13 03-26-2011 08:55 PM
Multiple Panel Question theatretch85 Electrical 5 12-12-2009 06:26 AM
