Old 06-12-2011, 07:12 PM   #1
broken_linkage's Avatar
DR chandelier wiring
Voltage meter shows hot wires when tested. After hooking up chandelier, no light and voltage meter shows NO 110-120. I switch the connections... same deal. I have ground wire screwed to junction box. I tested chandelier before hanging and did get it to light. Thanks for any help. getting frustrated Steve
broken_linkage is offline   Reply With Quote
Old 06-12-2011, 09:00 PM   #2
Did you say that the 120-120 comes back when you unhook the wires for the purpose of switching the connections? (And goes away again when you finish switching the connections?)
If you jiggle the wires does th light come on? Could be a broken wires inside the insulation.
Be sure you measure between hot and neutral, not hot and ground.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Wiring 220V Chandelier for 110V ntxcop Electrical 7 12-26-2012 06:00 PM
Need help with connecting chandelier wiring seminole1 Electrical 0 04-04-2011 01:41 PM
Chandelier wiring alacea Electrical 7 11-10-2010 01:32 PM
Need help wiring chandelier Mike2181 Electrical 12 10-04-2009 07:45 PM
Wiring the bottom of a chandelier maged Electrical 12 06-04-2009 02:36 PM
