Downgrage 20amp To 15amp - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-05-2012, 10:43 AM   #16
Electrical Contractor
jbfan's Avatar
Rewards Points: 490
It would be easier to take the white wire from the breaker and put it on the neutral.
Then you are done, without haveing to take the breaker out, install a new one, and install a filler plate.
No need to downgrade to 15 amp or #14 wire.
Old 04-05-2012, 10:46 AM   #17
Originally Posted by Jim Port View Post
The wiring can stay, but as I said some changes to some connections will need to be made.
Okay, but you are saying that wiring changes would need to be made even if I choose the single pole breaker and filler method?
yonkoc is offline   Reply With Quote
Old 04-05-2012, 10:48 AM   #18
jbfan's Avatar
Rewards Points: 490
Correct.
The same changes will have to be made anyway.
Old 04-05-2012, 10:50 AM   #19
Originally Posted by jbfan View Post
Correct.
Okay, I'll post pictures of what I see when I get back. How much should an electrician charge for a change like this one?
Old 04-05-2012, 05:41 PM   #20
Pics
Here are the photos from my panel.
Main panel in full view
Breaker in question
Old 04-05-2012, 05:48 PM   #21
Licensed electrician
Rewards Points: 1,632
Just remove the white wire from the breaker and put it in the unused hole in the bar with the other white wires. Relabel panel directory, done.
Old 04-05-2012, 06:17 PM   #22
That's it?!? And if I am to replace it with a 15amp breaker and use a filler breaker plate? I would use the black wire to the breaker, route the white one to the bar with the other white ones. I guess this is actually quite good as I was told I'd have to pay for a sub-panel build out if I ever needed to expand. That way I won't have to, and I'll use the additional circuit in the basement (thinking of moving my office there some time in the future. I'll probably opt for 20amp single pole breaker.
Recommendations for the breaker? I looked at home depot cause it is around the corner. Mine are GE, so the only 1inch option is this.
Btw, here are the pics (one and two) from the receptacle, the cable is 12/2 ga.
Old 04-05-2012, 06:37 PM   #23
jbfan's Avatar
Rewards Points: 490
I wouldn't change the breaker to a 15 at all.
I woouldn't change the breaker until yoou decide you need that other circuit.
I would change that low voltage cut out for a old work box.
The connections to the receptacle need to be inclosed inside a box.
You need one with the ears like you have now, but it will be blue.
Old 04-05-2012, 06:58 PM   #24
1. I won't! Listen and obey I shall.
2. How about I call you when I need that basement done
3. Yes sir, I guess you mean this.
On to HD. I will let you know how it goes.
From the bottom of my heart - thank you very much jbfan and Jim Port. Thank you!
Old 04-05-2012, 07:05 PM   #25
jbfan's Avatar
Rewards Points: 490
It is a long way to Duluth from Newnan!
Glad to help, and see that you can listen to reason!!
You don't happen to work for a company that relocated it headquarters from Dayton, do you?
Old 04-05-2012, 07:44 PM   #26
Not at all, not even from this continent I'm from across the the great pond to the east.
Old 04-05-2012, 08:56 PM   #27
If you even do decide to change the breaker it will need to match the panel brand.
15amp outlet on 20amp circuit?? mopowers Electrical 12 02-02-2010 01:35 PM
15amp to 20amp Carloscda Electrical 4 07-26-2009 10:38 PM
Is this correct regarding 20amp circuit and 15amp receptacles diymonkey Electrical 17 07-26-2009 06:57 PM
Can I use a 20amp outlet receptical on a 15amp circuit? abefroman Electrical 17 01-18-2009 09:57 PM
15AMP vs 20AMP for Office? mfleming Electrical 11 04-25-2008 08:50 AM
