#1 |
Doubling grounds in panel - twisting or not?
Howdy all,
My panel is rated to allow grounds to be doubled up. Do I want to twist 'em or just neatly line them up under the screw, or does it matter? It seems to me that so long as both wires are in that hole and that screw is tight, it wouldn't much matter, but ... "it seems to me" has gotten me into trouble in the past. I need to free up some spaces! Why someone would make a 40 circuit panel with only 20 connectors each for neutral and ground is beyond me. Even 25 would have been more reasonable. Thanks, Jim |
#2 |
Electrical Contractor
Add a ground bar kit. Move as many bare ground wires to it to free up neutral slots. ONE wire per slot for neutral connections.
I would not twist them. If you ever have to relocate one, it will be a big thing to undo all that twisting ... (just sayin') ...
-KB Life is uncertain -- eat dessert first!! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 | |
MarginallyQualified
Doubling grounds in panel - twisting or not?Quote:
But I'll also suggest that you get an additional ground bar to keep it neater... just don't separate it from the others. |
#4 |
Licensed Electrician
The bars aren't specifically 1 for grounds and 1 for neutrals. Main panels grounds and neutrals go to the same bars and likely that the two bars are bonded to each other. So, you have 40 spaces for grounds and neutrals not 20 spaces for grounds and 20 spaces for neutrals. Also, keep in mind that all circuits don't have grounding conductors, in fact, many use the metal raceway (EMT) as the ground path.
Not a fan of the new layout.
Answers based on the National Electric Code. Always check local amendments. |
#5 |
No they can't! See section 408.41
| The Following 2 Users Say Thank You to kbsparky For This Useful Post: | mpoulton (07-09-2012), stickboy1375 (07-07-2012) |
#6 |
Thanks all, for clarifying.
Jim |
#7 |
To clarify something . . .
I picked up a ground bar kit - bar and two mounting screws. It's branded for my panel so I anticipate no problems screwing it into the existing holes. The question is, "do I need to do anything Other Than attach it to the panel?" As I understand it, mounting it directly to the panel provides this bar's connection to ground and no grounding wire needs to be run from the existing bar to this one, correct? Just making sure... Thanks again, Jim |
#8 |
Right. The code changed... The conduit always used to accepted as the "equipment" ground, but no more - (sniffle...)
#9 |
Licensed electrician
Oh really? The NEC still recognizes metallic conduit as a grounding means.
Answers based on the National Electrical Code. Local amendments may apply. Check with your local building officials. |
| The Following 2 Users Say Thank You to Jim Port For This Useful Post: | jbfan (07-11-2012), stickboy1375 (07-10-2012) |
#10 |
E2 Electrician
Doubling grounds in panel - twisting or not? |
#11 |
Sorry...In California, the conduit is no longer allowed to be used as equipment ground - but California is always ahead of the game - just like in football, I guess...
#12 |
It would be helpful if you added where these code changes apply. Not everyone here lives or follows the California electrical code. I don't know why you would even put something out there from the CEC unless the OP was from California.
#13 |
I would like to see the exact code rule on this.
#14 | |
I decided to look it up myself...
From the 2010 CEC based on the NEC 08 feel free to look it up yourself ( http://ia700503.us.archive.org/20/it...title24_03.pdf ) page 232 Quote:
Answers based on the National Electric Code. Always check local amendments. Last edited by k_buz; 07-11-2012 at 11:09 AM. |
#15 |
Why spend money on a code book, when sooner or later someone will give you the answer you are looking for, right or wrong!
Yes I am a Pirate, 200 years too late. "Jimmy Buffett" |
| Display Modes | |
| Garage Sub Panel Questions | mscanlon01 | Electrical | 3 | 07-20-2011 11:03 AM |
| Grounds in panel | Russell | Electrical | 15 | 06-26-2011 06:34 PM |
| Subpanel next to Main panel wired the same in 1990 | Uncle Wayne | Electrical | 3 | 01-20-2011 01:43 AM |
| Moving several circuits to sub panel | WoodworkerDave | Electrical | 2 | 09-27-2008 03:05 PM |
| turn main panel into a sub panel? | tikicarver | Electrical | 2 | 01-24-2008 08:37 AM |
