Doubling Ground Wire On Neutral Bus Bar? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-19-2011, 05:33 AM   #1
Rewards Points: 38
Doubling ground wire on neutral bus bar?
I have to add a couple of 20 amp circuits to remodel our kitchen, though the bus bars in our panel are nearly full. The whole panel is nearly full, actually, though there is enough room for the new breakers, but not enough room for all the neutral and ground wires. My guess would be that they make panels with enough spots for all the wires from a full panel, but I think I am running short because of the few bedroom AFCIs I put in.
Anyway, my question is this: can I double up a couple of ground wires on the same screw on the bus bar? Is that an ok thing to do, or is there some other necessary solution?
Thanks.
dweeter is offline   Reply With Quote
Old 10-19-2011, 06:23 AM   #2
Lic Elect/Inspector/CPO
You can double up on ground wires, but not neutrals
NJMarine is offline   Reply With Quote
Ground vs. Neutral wire - bathroom fixture Narwal Electrical 4 08-14-2011 09:27 PM
Dimmer switch with Hot & Neutral wire ? Knucklez Electrical 3 12-28-2010 05:24 PM
Sharing Neutrals on the same phase electro Electrical 30 08-12-2010 03:10 PM
Real Basic Electrical question re: neutral wire hellothere123 Electrical 22 07-21-2009 07:07 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 07:30 PM
