Double And Triple Up On Buses? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-26-2009, 01:15 PM   #1
Rewards Points: 150
double and triple up on buses?
my panel's white bus and ground bus seems to not have any empty slots for added wire. is it ok to doule up or triple up on white and ground buses? i still have 5 slots to add breakers. i notice the previous owner also has ground on a white bus.
fabian is offline   Reply With Quote
Old 01-26-2009, 01:36 PM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Take the grounds off the neutral bar and put them with the grounds. You can double up on grounds (same size) and free up some space on the neutral bar.
wirenut1110 is offline   Reply With Quote
Old 01-26-2009, 01:50 PM   #3
No doubling on the neutrals, don't do that.
Grounds, assuming they are the same size, are ok.
rgsgww is offline   Reply With Quote
Old 01-26-2009, 02:11 PM   #4
Rewards Points: 26
Just out of curiosity and cause I'm trying to learn, why can't you double up the neutrals? Since they are basically touching each other since they are connected to the same bar? Also about the grounds, why can you only double up if they are the same size? Not questioning anybody but just trying to learn! Thanks
ponch37300 is offline   Reply With Quote
Old 01-26-2009, 02:22 PM   #5
the Musigician
DangerMouse's Avatar
never hurts to ask questions ponch, it's the people that DON'T ask questions we gotta worry about!
DM
Old 01-26-2009, 02:26 PM   #6
WaldenL's Avatar
Rewards Points: 268
I too have wondered about the issue w/neutrals and grounds on the same bus (in the first panel -- sub-panels are a different story) since the two buses are bonded anyway. I would guess (but it's a guess) that the size issue has to do with making sure that the smaller wire doesn't fall out when the screw gets stopped by the larger wire.
WaldenL is offline   Reply With Quote
Old 01-26-2009, 02:34 PM   #7
the Musigician
i think they mean a 14 on a 14 ground or a 12 on a 12 ground size, etc.
DM
Old 01-26-2009, 03:25 PM   #8
I believe the requirement to keep neutrals on their own terminal is for safety, especially during troubleshooting. (There is an exception to the rule, if there are grounded conductors or circuits with paralles conductors, and the terminal is identified for use with 2 conductors...)
Suppose you are working on circuit # 1, whose neutral is terminated in the same hole as circuit# 2, under one screw. You turned off the breaker for # 1, but not for # 2 because you're not disturbing that circuit. However, when you loosen the screw to isolate or remove the # 1 neutral, you now have a loose connection on the # 2 circuit while you are messing around. Not good, depending on how many amps are going thru that circuit.
Willis
williswires is offline   Reply With Quote
Old 01-26-2009, 03:36 PM   #9
WaldenL's Avatar
Rewards Points: 268
Good point on the multi-circuit issue. Anytime I'm messing around _in_ my box the main is off (yes, I know there's still live parts in there) so the multi-circuit issue is less of a concern. Not to dismiss the issue, but it sounds like it's an issue during change, but not an issue during operations. That reminds me, I need to post a pic of my box later to see how messed up people think it is. :-)
Old 01-26-2009, 04:17 PM   #10
Rewards Points: 510
YES, one thing I've been told since day 1 is, you don't want to be a neutral.
Double Flush and not all GONE hgiljr Plumbing 32 06-23-2008 07:42 PM
