Double Tap Question - Electrical - DIY Chatroom Home Improvement Forum
Old 04-08-2011, 10:01 AM   #1
Rewards Points: 77
double tap question
i have 2 double taps and i know to pigtail the wires together so that there are not 2 under the screw.
One problem i have is that there is a 20 amp breaker and 1 wire is 12 awg and 1 is 14awg. any solutions??
the only thought i had was i have another 15 amp breaker that only has 2 outlets and 2 lights and pigtailing the 14 awg onto that breaker.
rewiring and sepertating things is in my future, but i want to at least make it safer for the time being.
bryan1282 is offline   Reply With Quote
Old 04-08-2011, 10:04 AM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
yes, the #14 needs to be on a 15 amp breaker.. If that #14 is part of a MWBC, just be sure that whatever breaker you tag it to is on the same leg as the current breaker.
also, there are a few circuits in the house that are not to be shared with other areas of the house. Depending on how it is wired, that could be the bath and it definitely is the kitchen.
Old 04-08-2011, 10:06 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
If there is any 14 AWG wire in the circuit, the max breaker size must be 15 amps. It would be better to add a new 15 amp breaker and split the existing circuit up. If you do not have any spare slots or cannot use mini breakers, pigtail to an existing 15 amp circuit with a light load.
Coastal South Carolina
Double switch wiring rockclimber Electrical 18 03-18-2012 10:13 PM
Eliminating Double Taps in Older Sylvania 200A Panel Reilley Electrical 14 01-11-2009 04:52 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
hrv question indep HVAC 3 07-17-2008 10:39 PM
Basement vapor barrier question rob7young Remodeling 2 04-13-2008 09:10 AM
