Double Switch And Single Switch In Same Box? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-19-2012, 09:56 AM   #1
Double switch and single switch in same box?
I have a double box i need to wire up. There will be a single switch and a double switch in the box. I have one power wire coming in. I also have to hook up a wire that will feed another source in the same box so a total of five wires in the box. The double switch is for an exhaust fan and light. The single switch is for a recessed light. The other wire leads to a gfi and light. I can wire the double switch for the fan and the light and aslo to get power to my gfi. How do i get power to the songle switch next to the double switch pigtail?
Mallard1123 is offline   Reply With Quote
Old 09-19-2012, 10:56 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 474
Connect the incoming hot to the outgoing hot and add 2 pigtails, one to feed each switch.
jbfan is online now   Reply With Quote
Old 09-19-2012, 11:06 AM   #3
Ok i didnt know if it would be ok to run two pigtails. Thanks
Double switch wiring rockclimber Electrical 18 03-18-2012 10:13 PM
Powering a new single pole switch off of an existing three way switch set? jamesm067 Electrical 3 01-17-2012 07:36 AM
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-08-2011 11:00 PM
Problem with 230 volt double pole single throw switch rdempsey Electrical 6 06-23-2011 09:51 AM
single gang single pole switch on fan fabian Electrical 14 03-05-2009 01:11 AM
