Double Switch For Ceiling Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 11-20-2012, 05:47 PM   #1
Double Switch for Ceiling Lights
I just changed two of my hallway lights.
They're operated by two switches but I'd like to be able to dim.
Can I just replace one switch with a dimmer?
Switches work independently so I guess they're wired in parralel, right?
Please give me your advice.
Olograph is offline   Reply With Quote
Old 11-20-2012, 05:52 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
If there are two fixtures independently controlled by two separate switches, you would need to replace each switch with a dimmer for both the fixtures to dim.
If these two switches are in the same box, you could pigtail the switch legs together and use one dimmer, but then the second switch would be disabled.
Old 11-20-2012, 05:58 PM   #3
Two fixture controlled together by both switches. Basically, each switch control both fixtures.
There's one switches and the entrance and one at the exit of the hallway.
Old 11-20-2012, 06:02 PM   #4
k_buz's Avatar
Originally Posted by Olograph View Post
Switches work independently .
Then they don't work independently. Buy a 3-Way dimmer and replace one switch with the dimmer. Be sure to mark which wire is on the common screw of the existing switch. Even better, take a picture so you can reference it if you have problems.
The Following User Says Thank You to k_buz For This Useful Post:
Olograph (11-20-2012)
Old 11-20-2012, 06:04 PM   #5
Can I leave the other switch as it is?
Old 11-20-2012, 06:05 PM   #6
k_buz's Avatar
Yes.....
Old 11-20-2012, 06:16 PM   #7
LOLL, just wanted to be sure thanks
wired new lights and now the switch turns off and on all my lights naty0629 Electrical 14 05-18-2012 01:03 PM
Help with Two Switches & Two Lights simplyphp Electrical 36 11-25-2010 03:47 PM
Dimmer switch is warm even when lights are off! gonzo Electrical 17 05-25-2010 08:10 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
Wiring Outlets Then Switch Then Lights heydj Electrical 9 05-07-2009 09:09 PM
