Double Rocker Switch Question - Electrical - DIY Chatroom Home Improvement Forum
Old 04-24-2013, 11:33 AM   #1
double rocker switch question
Hi,
If I have 4 pot lights and I want 2 to be controlled by one switch and the other by the remaining switch on the double rocker I would break the tab to create a separate circuit on the switch, right and use both common terminals?
markharmon is offline   Reply With Quote
Old 04-24-2013, 12:13 PM   #2
Rewards Points: 150
Yeah. Although, going to the outlet, you've most likely got only 1 switched hot line. So you can't do this unless it was wired to handle two switched lines to that outlet. If it was, then you'd break the tab on the duplex receptacle, and wire one screw terminal up to each of the output terminals on the switch.
SquishyBall is offline   Reply With Quote
Old 04-24-2013, 12:32 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 224
Got a model # of the switch.
They should have a common hot side and separate switched sides.
Old 04-24-2013, 02:17 PM   #4
I have a 30amp double pole breaker but the outlet I want to feed is 120v. Can I still use the double pole breaker but just disconnect one of the hot wires and use it as a single pole breaker? Also, if its a 3 wire double pole which is 120/240v can I wire it to a 120/240v outlet and still use 120v appliances. If I wanted to add a switch to this it would need to be a 120/240 switch, correct?
Old 04-24-2013, 02:51 PM   #5
Rewards Points: 150
Do you mean you're trying to daisychain a 120V outlet off something like a dryer outlet? No, you shouldn't do that because a 30A 120/240 outlet is supposed to be a dedicated circuit and only serve the one appliance.
If instead you mean can you turn your 30A 120/240 into a simple 20A 120, sure you can do that. You're just running bigger than necessary wire and not using one of the conductors. If you're going to have a 20A outlet on the end, then you need to change out that breaker to a 20A breaker. A regular 20A breaker is like $4.
Not really, cuz you're going to be putting in a 20A duplex receptacle, right? That has to be protected by a 20A breaker.
Well, if you wire it to a 120/240V outlet, that's either going to be the 4-prong push-in plug or a 4-prong twist lock plug. What 120V appliance are you going to find to fit that plug? Those appliances are going to have a normal 15A plug, which will plug into a 15/20A receptacle, which need to be protected by a breaker at 20A not 30A.
What exactly do you have, and want to switch to? Cannibalizing a dryer circuit to put in a household branch outlet circuit seems wasteful.
Old 04-24-2013, 03:16 PM   #6
Ok, so 120/240 outlets only take 4 prong appliances? So, if I dont need the 240v breaker and I just want 120 I can't still use the double pole breaker just remove one of the hot legs?
Old 04-24-2013, 03:22 PM   #7
jbfan's Avatar
Rewards Points: 224
No.
General purpose receptacle can not be protected by higher than a 20 amp breaker.
You must replace the breaker if you want to use a 15 or 20 amp receptacle.
Old 04-24-2013, 04:12 PM   #8
Originally Posted by jbfan View Post
No.
what is the current breaker is a double pole 20 amp breaker? Can I just remove one of the hot legs from the breaker?
Old 04-24-2013, 07:43 PM   #9
jbfan's Avatar
Rewards Points: 224
Yes, as long as you have a neutral and a ground wire.
Old 04-24-2013, 08:18 PM   #10
Blank
I don't think it can be stressed enough that you can not use a 15 or 20 amp receptacle with a 30 amp breaker.
Baxter01 is offline   Reply With Quote
Old 04-24-2013, 11:16 PM   #11
Do 120/240v outlets require 4 prong devices?
Old 04-25-2013, 07:27 AM   #12
jbfan's Avatar
Rewards Points: 224
most cases, yes.
What are you trying to do?
Pics and, or info of the equipment will be quite helpful!
Old 04-27-2013, 11:47 AM   #13
Bill Kearney
Rewards Points: 1,174
You'd help us all a lot more if you explained WHY you want to do something, not just whether or not a particular setup can be changed. This because not everything can be simplified or reduced in they ways you're thinking.
As in, breakers are designed to be the weakest link in the wiring circuit. The idea is if you start pulling too much current for the wire to handle then the breaker will trip BEFORE the wire overheats. That and the electrical code specifies which gauge (thickness) of wire is rated to handle certain loads. This so if someone comes along later and finds a particular gauge wire in the wall they'll have a rough idea of what the circuit for it is designed to support. This is why you generally should NOT use heavier gauge wire for a lesser circuit. Because someone might pull apart that wiring later and make 'assumptions' about what's there and how it can be used. If you've gerry-rigged something that isn't to code then you might be setting things up for BIG problems later.
So it really comes back to "what are you trying to accomplish" and this leads to "what do you have available". These two questions are key to just about all home improvement scenarios.
wkearney99 is offline   Reply With Quote
Help Requested for Changing Double Switch to Two Singles eddj Electrical 27 12-01-2012 02:04 AM
Help wiring for double switch - and why the hot white wire? BusterT Electrical 4 10-20-2012 01:37 PM
Simple question regarding Wall Switch wiring kebrein Electrical 6 11-25-2011 08:54 PM
double switch wiring problem avalanchehunter Electrical 5 12-13-2009 02:00 PM
Wiring Double Switch fan/light mjbcable Electrical 5 10-18-2009 07:56 PM
