Double Pole Gfci - Electrical - DIY Chatroom Home Improvement Forum
Old 08-06-2012, 06:38 PM   #1
double pole gfci
can I use a double pole GFCI breaker if there is no neutral wire
islander2 is offline   Reply With Quote
Old 08-06-2012, 06:41 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
The line side requires it, the load side does not. In other words, the GFCI breaker itself requires a neutral connection for the electronics to function.
Double Pole 15A on/off switch?? Skelleyman Electrical 5 05-01-2012 05:01 PM
double pole GFCI tripping jeffrs Electrical 0 02-27-2012 12:39 PM
double pole breaker + outlets / x10 BlueBSH Electrical 0 09-09-2010 01:44 PM
Double pole breaker v/s single pole breaker schultz56 Electrical 3 02-09-2010 02:12 PM
GFCI Question Mdbuilder Electrical 6 06-19-2008 04:15 PM
