Old 07-09-2008, 12:26 AM   #1
Double pole CH breaker ??
Hey all. I am replacing a double pole breaker in my panel, It's a Cutler Hammer ch 20 amp. By the breakers lugs there are stickers. By one lug it says common trip. And the other sticker by the other lug just has the breaker ratings. Would the common trip be the black wire in the 240 circuit? And why would there be a common trip side of the breaker shouldn't both legs be equally protected.
James Con is offline   Reply With Quote
Old 07-09-2008, 12:53 AM   #2
Electrician's Helper
Pudge565's Avatar
Send a message via AIM to Pudge565
The common trip probably means that if one pole of the breaker is overloaded it will trip both poles (which is required by code).
Pudge565 is offline   Reply With Quote
Old 07-09-2008, 01:18 AM   #3
Power Gen/RS Engineer
"Common trip" simply means that either breaker tripping will open both conductors, i.e. both "legs" via a handle that ties both handles together. Color has nothing to do with it! In a 240V circuit breaker, both poles are designed to open simultaneously. If not (i.e. if only one pole opened, the other would remain closed presenting a life and/or fire hazard).
Jimmy
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves,"You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." - George Carlin
BigJimmy is offline   Reply With Quote
Old 07-09-2008, 01:59 AM   #4
Ahh! Being it is a doublepole they trip simultaneously as needed in a mwbc. So by them saying common trip they mean both trip at once because of the handle ties. I thought maybe it had to do with which wire (Black, White) goes to a certain lug which did not make sense cause both sides of the breaker are identical. What threw me off was the word Common. Makes sense now. Thanks
Old 07-09-2008, 04:18 PM   #5
CH probably should not have placed the lable "common trip" next to one of the lugs.
When in doubt, you can always go to the web site and look at the specs.
FW
fw2007 is offline   Reply With Quote
Old 07-09-2008, 11:28 PM   #6
Pudge565's Avatar
Or if you want to be a smart @$$ you caould take it that the breaker is going to trip alot.
Old 07-09-2008, 11:39 PM   #7
Umm, ok, I don't get it?
Old 07-10-2008, 12:41 AM   #8
Pudge565's Avatar
Meaning that it tripping would become very common.
Slimline Vs. Tandem Vs. Double Pole turd hurder Electrical 1 06-23-2008 04:00 AM
Three way light switches and double pole breaker ShawnColes Electrical 6 04-15-2008 09:25 PM
Novice Replacing 60 amp double pole breaker Ayreonna Electrical 40 02-19-2008 02:26 AM
single vs. double breaker Neil_K Electrical 3 11-15-2004 12:02 AM
2 pole breaker Unregistered Electrical 3 09-11-2004 12:15 PM
