Double Pole 15A On/off Switch?? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-01-2012, 11:33 AM   #1
Rewards Points: 77
Double Pole 15A on/off switch??
Hello again Gurus,
Will a double pole 15A 277v light switch work as a shut off for my air handler? I had to run all the electrical prior to them installing the central air and I wired a double pole switch from my 15A double pole breaker. I ran to the line/load ie black/white to the bottom posts on the switch. Thinking they can just run black/white from the air handler to the top. When the switch is UP> Live power to air handler. If it it's down (OFF), it means they can service the unit. Is my thinking correct on this? I couldn't find any other switches.
Thank You
~S
Skelleyman is offline   Reply With Quote
Old 05-01-2012, 11:42 AM   #2
Cruising into the sunset
JulieMor's Avatar
Rewards Points: 518
Are you talking about providing a disconnect to the A/C condenser unit outside your home? Or you talking about an air handling unit in a commercial application?
JulieMor is offline   Reply With Quote
Old 05-01-2012, 11:49 AM   #3
Rewards Points: 77
Nope, not the disconnect but the actual air handler. Need's to be on on/off switch much like a furnace or hot water heater. This is code for service and since my breaker/panel is not on the same level as the air handler. This should work, correct?
Old 05-01-2012, 12:37 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
It'll work, but a $10 pull-out disconnect will do the job MUCH easier and cheaper.
Old 05-01-2012, 02:48 PM   #5
Rewards Points: 77
Thanks. I ran 14/2 as well. Some electricians say that 12-2 is better. Others sa 14/2 should be fine because air handlers only draw 2-3 amp max.
Old 05-01-2012, 04:01 PM   #6
For a 240v air handler #14 is FINE unless the distance is real far, like well over 100'.
You're right, 240v air handlers have almost no draw.
Double pole vs single pole question Araucaria Electrical 5 04-24-2012 08:20 PM
Replacing single pole light switches with double pole bruce54 Electrical 43 04-15-2012 10:23 AM
Problem with 230 volt double pole single throw switch rdempsey Electrical 6 06-23-2011 09:51 AM
HELP.. trouble adding light to single pole switch RickDel Electrical 13 09-09-2009 10:18 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 07:59 PM
