Double Ground Connections Or Pigtail In Receptacle Outlets? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-05-2012, 09:59 AM   #1
custom user
Rewards Points: 150
double ground connections or pigtail in receptacle outlets?
Hey y'all,
This question is for a friend (yes really). I was over at his home last night and he showed me his newlt built garage. He and his son wired it, they are almost done and need it inspected soon.
He had covers off on a few because he was told the inspector will want to peek inside. Others told him no, he'll take the covers off if he wants.
I noticed that they doubled up on the ground wire to the receptacle. Ground to the metal box and ground coming in are terminated on the same screw on the receptacle. Is this Kosher? I thought it would have been better had they pigtailed and only had one wire on the screw.
What say ye?
(WA State, if it matters)
JasperST is offline   Reply With Quote
Old 12-05-2012, 10:10 AM   #2
Licensed electrician
Rewards Points: 1,268
One conductor per screw head. The grounds need to be connected to each other and pigtailed to the box and receptacle. Your friend has some work to do.
Old 12-05-2012, 10:13 AM   #3
Rewards Points: 2,516
Do you mean like this where the end of the ground is going to the device(switch...receptacle)
double ground connections or pigtail in receptacle outlets?-electric-20box.jpg
hammerlane is offline   Reply With Quote
Old 12-05-2012, 10:20 AM   #4
like this?
Old 12-05-2012, 10:32 AM   #5
custom user
Rewards Points: 150
Not quite. No bare ground wires for one thing. He has a green wire screwed to the box ground with a spade connector on the other end connected onto the receptacle ground screw, shared with the ground wire coming in from the flex conduit.
It will work but I don't know if it will pass muster.
Old 12-05-2012, 10:33 AM   #6
custom user
Rewards Points: 150
Ooops. I apparently scrolled by your post. That's what I thought. Are bare wires a requirement or does it matter?
Old 12-05-2012, 10:40 AM   #7
so the ground screw of the receptacle has two wires under it?
Old 12-05-2012, 11:00 AM   #8
Electrical Contractor
jbfan's Avatar
Rewards Points: 252
Bare wires are not required, but all grounds connected together and one wire under each screw.
Old 12-05-2012, 11:11 AM   #9
custom user
Rewards Points: 150
Yes, two wires on the ground screw of the receptacle. Sounds unanimous that it won't fly. I hadn't seen it before so I was skeptical.
Thanks for the input.
Old 12-05-2012, 11:57 AM   #10
Special User
Rewards Points: 1,230
These kind of wire nuts may be useful when fixing this situation:
Proper Use of Green Wire Nuts
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 12-05-2012, 12:58 PM   #11
Rewards Points: 1,448
Wait a minute! If wires have spade lugs attached, can't a number of the spade lugs plus one wire curled around the screw share the same screw?
Old 12-05-2012, 01:03 PM   #12
Rewards Points: 3,130
I don't understand why people don't use plastic boxes. Wouldn't have this issue to worry about.
Old 12-05-2012, 01:23 PM   #13
plastic sucks...metal better
Old 12-05-2012, 04:18 PM   #14
custom user
Rewards Points: 150
It's a four bay garage/shop. Not commercial but setup for welding and wrenching. All metal conduit and boxes.
Old 12-05-2012, 04:20 PM   #15
eastcoastsparky's Avatar
Rewards Points: 150
Hey y'all,
What say ye?
is this the rough inspection, if it is no devices or covers can be installed
eastcoastsparky is offline   Reply With Quote
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-09-2011 12:00 AM
20amp receptacle no ground wire moschmo Electrical 2 12-09-2010 11:11 AM
Replacing outlets: Pigtail, or don't pigtail? bassman99 Electrical 17 05-05-2009 03:50 PM
Hot Tub Install--Grounding Rod Question statgeek_rob Electrical 16 09-15-2007 03:59 AM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 07:30 PM
