Double Gang Receptacle - Electrical - DIY Chatroom Home Improvement Forum
Old 09-07-2010, 08:40 PM   #1
How do I wire a double gang receptacle where the wire goes on to power another receptacle.
cleanmchn is offline   Reply With Quote
Old 09-07-2010, 08:44 PM   #2
Pig tail the wires
macdonald is offline   Reply With Quote
Old 09-07-2010, 08:47 PM   #3
Rewards Points: 81
Agreed or you can rabbit ear but in your case just pigtail.
Chevyman30571 is offline   Reply With Quote
Old 09-08-2010, 01:25 AM   #4
" Euro " electrician
frenchelectrican's Avatar
Two ways it can be done depending on the numbers of cable in the box.
First is pigtail which it is most common method.
Second is Jumper mode this is little tricky but only if you have one or two cable only { ground will be pigtail anyway } so one set of cable wires will go to first screw then a short peice { about 8 inches or so } will jump over to other recetale and the other conductors can be tied on the rest if need to.
So that the two ways I have done for many years IMO it little easier to use the pigtail if you have deep box but shallow box it kinda toss up depending on numbers of cable or conductors in the juction box.
Merci.
Marc
Old 09-08-2010, 11:16 AM   #5
Just call me Andrew
Rewards Points: 1,020
When you say "double-gang receptacle" do you mean...a 2-gang box with TWO outlets in it, or a duplex receptacle?
Basically, how many of these are in the box:
Andrew
secutanudu is offline   Reply With Quote
2 gang old box, made into 3 gang, off center?? fabian Electrical 9 01-15-2010 10:46 AM
single to double gang remodel DIYGST Electrical 3 01-02-2010 07:33 PM
Increase to double gang boxes... jamiedolan Electrical 20 10-17-2008 01:21 PM
Double gang outlet box TaazKareem Electrical 3 09-29-2008 11:00 PM
Double receptacle circuit TonyD Electrical 4 11-14-2006 08:00 AM
