Double Gang Outlet Box - Electrical - DIY Chatroom Home Improvement Forum
Old 09-29-2008, 07:00 PM   #1
Double gang outlet box
Hey hoping someone can shed some light on me. I am gettin ready to install 4 new double gang outlet boxes and wire 8 new receptacles (2 in each of course). I understand how the wiring goes with single outlets. But how does it work with double. I know the concept of the current passing thru it, but how would I wire the ground. There's only one green screw on a receptacle, so how would I wire it to go thru each receptacle in the box and continue to the next box. Or do you do it some other way. Thx in advance
TaazKareem is offline   Reply With Quote
Old 09-29-2008, 07:15 PM   #2
Electrical Contractor
kbsparky's Avatar
You can either:
  • Twist both bare wires together, and then use a crimp sleeve half-way out making a good electrical connection, and leaving 2 tails for connection to the outlets
  • Use a wire-nut on both leads, and "pigtail" 2 leads from that -- one to each outlet
Old 09-29-2008, 09:49 PM   #3
Electrician
Rewards Points: 802
You could leave your ground long go around one ground screw and then on to the other one. So one long wire picks up both.
darren is offline   Reply With Quote
Old 09-29-2008, 10:00 PM   #4
Electrician
You would still need a mechanical connection from box to box, a device cannot do this, thats why only one ground screw on each device.
chris75 is offline   Reply With Quote
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 09:05 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 03:59 PM
20a Outlet Vs. 15a Outlet bobo Electrical 3 05-29-2006 10:55 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 08:45 AM
