Double Fed Receptacle - Electrical - DIY Chatroom Home Improvement Forum
Old 06-09-2012, 08:05 PM   #1
Double fed receptacle
I have a switch connected to a duplex receptacle using 14-3. The black is tied into the hots in the switch box and terminates on the top brass screw of the duplex plug. The red is attached to the switch and terminates on the lower brass screw on the plug. Simply put its a duplex receptacle with one plug operating off the switch and one plug hot all the time. This circuit has a 14-2 home run in the switch box and it connects to a single 15A breaker in the panel. My question is if the tab between the two plugs is to not removed will the breaker trip every time the switch is turned on? My initial thought was no this would not happen....the switch would just be rendered useless. I was thinking if we were bumping different phases by using a double pole breaker than it would trip. Am I headed in the right direction?
Thanks for any and all help,
Marcus
Hexamexapex is offline   Reply With Quote
Old 06-09-2012, 08:44 PM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,970
You are exactly right. If the tab is not removed, the switch won't do anything and the receptacle will be hot all the time. If the receptacle were fed with a multi-wire branch circuit with each half served by a different leg, then the tab would create a 240V dead short.
mpoulton is offline   Reply With Quote
Old 06-09-2012, 09:39 PM   #3
Excellent! Thank you for your response.....the last forum I posted that question I got rolling eyes. Wrong forum I guess.
Thanks again,
Marcus
Double Hung vs Single Hung CZSteve Remodeling 0 11-08-2010 07:29 AM
Welder Receptacle - What Electrical Box SNAFU Electrical 4 10-26-2010 09:45 PM
Wiring a receptacle for a lift station hydrogeo99 Electrical 4 08-18-2010 01:04 AM
Replacing duplex receptacle with nighlight - wiring question Rabu Electrical 6 05-02-2010 07:51 PM
Installing new wall receptacle... jaysen Electrical 18 06-10-2008 08:26 PM
