Double-ended Halogen Sockets - Electrical - DIY Chatroom Home Improvement Forum
Old 02-09-2011, 02:43 PM   #1
double-ended halogen sockets
there was a double-ended halogen light in my dinning room, however the sockets oxidized and burned away, so I bought worklight from homedepot and took out the ceramic sockets and replaced the bad ones. after that I checked the circuit with voltage tester and the LED light up, however the light bulb won't light up. I tested 150 W and 300 W double-ended halogen bulbs, none of them work. appreciate your any suggestions about what's wrong in my repair!! thanks in advance.
feng is offline   Reply With Quote
Old 02-09-2011, 03:00 PM   #2
I'm guessing that the bulb is not seating properly in the contacts, but it's hard to be sure. Can you post some pics of the fixture with and without the bulb installed?
clashley is offline   Reply With Quote
Double switch wiring rockclimber Electrical 18 03-18-2012 11:13 PM
Replacing undercabinet halogen bulb with xenon bulb gabbie14 Electrical 10 09-26-2011 11:46 PM
Double Hung vs Single Hung CZSteve Remodeling 0 11-08-2010 08:29 AM
double pole breaker + outlets / x10 BlueBSH Electrical 0 09-09-2010 01:44 PM
How Does A Double Pole Circuit Breaker Trip? shadowx360 Electrical 2 07-09-2008 03:44 PM
