Double Doorbells - Electrical - DIY Chatroom Home Improvement Forum
Old 03-10-2008, 05:04 PM   #1
Question
Double Doorbells
I'm installing new doorbells in my older house. Due to the acoustics, I want to use 2 chime boxes (one for upstairs, one for down). Should these get wired in series? And do I need a stronger transformer to power both?
Thanks.
Altricious is offline   Reply With Quote
Old 03-10-2008, 05:12 PM   #2
Electrician
Thanks.
They would get wired in parallel, and you would need to check the VA of each chime to determine the size of the transformer.
chris75 is offline   Reply With Quote
Old 03-10-2008, 05:22 PM   #3
no, parallel
Possibly, though not likely in my experience. Just try it.
They also make a wireless "extend a chime" if hardwiring is an issue.
220/221 is offline   Reply With Quote
Old 03-10-2008, 05:46 PM   #4
I saw those, but I'm just as happy running the wire. One system, one power source. Then I don't have to worry that the crazy dogs have unplugged the other half of the chime system.
Thanks for the speedy response on this. I think I'll test the configuration before I run all the wires. Then if I need to find a better transformer or something I won't be surprised.
Double glazed doors Big Al Building & Construction 6 04-19-2008 06:09 PM
double sink gurgles! Bcoleman6 Plumbing 4 02-24-2008 09:49 PM
Single Sink To Double Sink 39centstamp Plumbing 4 06-24-2007 10:27 AM
single vs. double breaker Neil_K Electrical 3 11-14-2004 11:02 PM
