Double Dimmer Switch? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-17-2014, 02:12 PM   #1
Double dimmer switch?
I have a lutron double switch, esch switch controls a light in the kitchen. I have hockey puck lights over the sink and a overhead track light for a portion of the kitchen. I want a double dimmer switch to use as dimmers for each light.. Is this possible?
Thanks,
Keith
Homerlion is offline   Reply With Quote
Old 01-17-2014, 02:41 PM   #2
Licensed electrician
Rewards Points: 1,876
You will need two dimmers in a 2 gang box.
Old 01-17-2014, 03:11 PM   #3
Oso954's Avatar
Rewards Points: 1,654
Lutron does make one.
http://www.homedepot.com/p/Lutron-Ma...s#.Utmbb7TTmUk
But, you are limited to 300W per switch.
You will also run into box fill problems, unless you have a large and deep box.
The 2 dimmers in a 2 gang is probably the better way to go.
Oso954 is offline   Reply With Quote
Help Requested for Changing Double Switch to Two Singles eddj Electrical 27 12-01-2012 01:04 AM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 02:44 PM
Dimmer Switch Question Livewire78 Electrical 6 01-03-2010 09:51 PM
Need help installing a dimmer switch { PICTURE } Brieninsac Electrical 8 11-20-2008 12:25 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
