Double Checking If This Is Wrong Or Not. - Electrical - DIY Chatroom Home Improvement Forum
Old 12-12-2012, 03:38 PM   #1
langless28's Avatar
Rewards Points: 152
double checking if this is wrong or not.
i know in the back of my head this is not to code but i thought i would ask just in case. i have a 1/2" pancake box attached to the outside of the house. i built these little blocks so that the light fixture has a nice extended look when the shingles go up around it. the pancake box needs to be 1/8" min from the front face and it cannot be this far back correct? can i add material between the house and pancake box (and not the surround) to bring it closer to the front face?
langless28 is offline   Reply With Quote
Old 12-12-2012, 04:18 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 546
You can remove the box and put spacers behind, or get a round box extension for the front.
Double switch wiring rockclimber Electrical 18 03-18-2012 10:13 PM
Double wall oven with 4 wire, grounded conductor traxman Electrical 4 05-02-2011 09:31 PM
wrong door opens with double front entry bernersnuggler Building & Construction 4 06-14-2009 11:46 AM
Double Tapped Fuses john8791 Electrical 4 05-17-2009 02:16 AM
Eliminating Double Taps in Older Sylvania 200A Panel Reilley Electrical 14 01-11-2009 04:52 PM
